DonovanPorter Posted October 31, 2014 Share Posted October 31, 2014 Good morning all i'm not what caused this but i get a blank tab , when i select new tab... i've tried changing the variables but none return it to having all the tabs displayed Quote Link to comment Share on other sites More sharing options...
DonovanPorter Posted October 31, 2014 Author Share Posted October 31, 2014 opposed to this Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 31, 2014 Share Posted October 31, 2014 Did you try shutting down AutoCAD then restarting it? What variables were you mucking around with? Were you making changes via the Options dialog box prior to this situation occurring? Quote Link to comment Share on other sites More sharing options...
Dana W Posted October 31, 2014 Share Posted October 31, 2014 This may not be it, but check to make sure both NEWTABMODE, and FILEDIA are both set to . Quote Link to comment Share on other sites More sharing options...
DonovanPorter Posted November 3, 2014 Author Share Posted November 3, 2014 Good Morning Guys i have cycle though the options of NEWTABMODE -1,2,3. FILEDIA is currently set at 1 i have tried shutting down and restarting , no difference. i cant recall making any changes in the options dialog other than, crosshair, fade control and such. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted November 3, 2014 Share Posted November 3, 2014 I guess that the menu is unloaded or being unloaded by a user with the toolbars as well , so try to reinstall the program from the Control Panel > Select AutoCAD 2015 then Uninstall/Change then you should receive a message to Uninstall or Remove .. etc then chose Reinstall . Quote Link to comment Share on other sites More sharing options...
DonovanPorter Posted November 3, 2014 Author Share Posted November 3, 2014 (edited) from the start menu i have the following > Autodesk>AutoCAD 2015 LT>Reset Setting To default. Edited November 3, 2014 by DonovanPorter Quote Link to comment Share on other sites More sharing options...
DonovanPorter Posted November 4, 2014 Author Share Posted November 4, 2014 i have reset AutoCAD to defaults, still have the same reault Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 4, 2014 Share Posted November 4, 2014 Have you tried a REPAIR of this installation? Quote Link to comment Share on other sites More sharing options...
DonovanPorter Posted November 4, 2014 Author Share Posted November 4, 2014 no i have not tried a repair. how do i go about doing a repair ? Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 4, 2014 Share Posted November 4, 2014 It is accessed through the Windows Control Panel > Programs and Features. Note: A REPAIR is not the same as an uninstall/reinstall. When you say you tried to reset AutoCAD's default settings did you in fact reset your Profile via the Options dialog box? Quote Link to comment Share on other sites More sharing options...
DonovanPorter Posted November 4, 2014 Author Share Posted November 4, 2014 i used the "reset settings to default" option through windows start menu. i will try the repair, and post my findings. thank you ReMark Quote Link to comment Share on other sites More sharing options...
DonovanPorter Posted November 4, 2014 Author Share Posted November 4, 2014 i done the repair , but no difference. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 4, 2014 Share Posted November 4, 2014 Just out of curiosity when did this first occur? Quote Link to comment Share on other sites More sharing options...
DonovanPorter Posted November 4, 2014 Author Share Posted November 4, 2014 i have had the programme for about 4 months of which i think it was almost a week that i had the new tab working correctly. i think it might have been a setting that is switched off, because of the curiosity of the new version. but then again i could be wrong. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 4, 2014 Share Posted November 4, 2014 Try resetting your Profile via Options > Profiles tab > Reset. Quote Link to comment Share on other sites More sharing options...
DonovanPorter Posted November 4, 2014 Author Share Posted November 4, 2014 AutoCAD LT does not have (support) profiles. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 4, 2014 Share Posted November 4, 2014 Sorry...I should have remembered. I tried to duplicate your situation on my computer but couldn't. Could you swing by and show me what you did? I like learning new and esoteric things. Quote Link to comment Share on other sites More sharing options...
DonovanPorter Posted November 4, 2014 Author Share Posted November 4, 2014 no worries. quite the distance between us couple thousand kilometers. for the life of me i wish i knew what i had done. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 4, 2014 Share Posted November 4, 2014 You apparently came down with a severe case of clickitis. I had a manager that got it so bad he once had over fifty copies of Windows Explorer open on his desktop. What is the current value of NEWTABMODE? Quote Link to comment Share on other sites More sharing options...
