danielk Posted November 1, 2014 Share Posted November 1, 2014 i change my attribute values inside the "block editor" when exisitng and save , the block is still with the old values . tried ATTSYNC , REGEN . Thanks Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 1, 2014 Share Posted November 1, 2014 you shouldn't be changing the attribute values inside the block editor, they should be changed in the attribute editor. Double click the block and change them there. Quote Link to comment Share on other sites More sharing options...
Ski_Me Posted November 5, 2014 Share Posted November 5, 2014 You could use attedit then click on the block you want to change. I use block editor for blocks I'm going to use in my drawings not on blocks already in my drawings if that makes sense. Quote Link to comment Share on other sites More sharing options...
SUNNY60 Posted November 5, 2014 Share Posted November 5, 2014 Hi Please kindly help me out on Attribute name in AutoCAD Lt. I have created a block with Attribute name. Please how can I edit the attribute name. I try changing it through Editing Attribute Definitions but not working. please send me some information to help out. Thanks Sunny Quote Link to comment Share on other sites More sharing options...
danielk Posted November 5, 2014 Author Share Posted November 5, 2014 You could use attedit then click on the block you want to change. I use block editor for blocks I'm going to use in my drawings not on blocks already in my drawings if that makes sense. o.k , learned something! Thanks ! Quote Link to comment Share on other sites More sharing options...
SUNNY60 Posted November 5, 2014 Share Posted November 5, 2014 May I thank you for your support, it works fine nice for your help. Thanks Sunny Quote Link to comment Share on other sites More sharing options...
