Results 1 to 4 of 4
    Full Member
    dal-designs's Computer Details
    Windows 7
    HP Compaq Elite 8300 SFF
    Construction
    dal-designs's Discipline Details
    Designer in Oil and Gas Industry
    Construction
    facilities planning (retail/wholesale fuels and chemicals) aerial surveying and GIS mapping; building design, facilities planning, land development
    AutoCAD 2015
    Feb 2014
    Victoria, Texas
    54
    Default QLEADER and/or QLATTACH Issue?
    I am trying to QLATTACH some errant leaders to their respective text. In my QLEADER (S)ettings I have:
    Annotation
    Type: Mtext
    Options: prompt for width
    Reuse: None
    Leader Line & Arrow
    Leader Line: straight
    Arrowhead: closed filled
    First segment constraint: any angle
    Second segment constraint: horizontal
    Multiline Text Attachment
    Text on left side: middle of bottom line
    Text on right side: middle of top line
    Underline bottom line: unchecked
    However, when I QLATTACH the leader to text, it wants to add a point to the leader and either underline the bottom line (which is unchecked, remember) or maybe it is trying to associate with the middle of the bottom line instead of the middle of the top line (text is all justified to top left).
    See attached. The top leader and mtext is what it should look like; the bottom leader and mtext is what I get when I try to QLATTACH. I'm probably overlooking something simple, but I can't figure out what it may be. Something in STYLE, maybe?
    AutoCAD 2013
    Nov 2011
    6,056
    I am too busy to test this, but I believe you want to use the settings as shown in the image.
    Full Member
    Windows 7
    Construction
    Construction
    AutoCAD 2015
    Feb 2014
    Victoria, Texas
    54
    Quote Originally Posted by Dadgad View Post
    Thanks for the advice, but that didn't work. Same issue.
    Our standards (which I somewhat disagree with, but what you gonna do?) are that all callouts are justified upper left, regardless of if the leader goes right or left. BUT text on the right has the leader attached at middle of top line, while text on the left has the leader attached at middle of bottom line. Again, these are office standards I cannot change, being as I am a drafter peon.
    If I were making new callouts with qleader, there would be no problem. But we're working on cleaning up and fixing a metric buttload of legacy details and specs, so I fear doing that will take more time than my workaround...which is shown in the attached pic. Basically, I draw a line where I want the leader to associate, then QLATTACH. That puts the leader at the upper left (which is the text justification, keep in mind). But if I grab the leader's endpoint and drag it to the anchor line, it associates correctly.
    Sucking at something is the first step to being kinda good at it
    Full Member
    Windows 7
    Construction
    Construction
    AutoCAD 2015
    Feb 2014
    Victoria, Texas
    54
    New details are available:
    I confronted our architect whom we originally got the details from, and he admitted that the leaders and mtext were never associated- they were drawn as mtext, then leaders were drawn separately to the mtext. QLEADER was never used. This may explain why QLATTCHing the leaders snaps them to the mtext origin, and not where QLEADER (S)ettings says it should snap- and I don't know if there's any way to really fix it...
  1. QLeader on 3D?
    By fbby in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Feb 2010, 06:44 am
  2. Qleader
    By flowerrobot in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Nov 2008, 06:29 am
  3. Qleader
    By flowerrobot in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Sep 2008, 07:48 am
  4. QLEADER help
    By Evil_eyes in forum AutoCAD Beginners' Area
    Last Post: 7th Apr 2008, 05:18 pm
  5. Qleader
    By vinod in forum AutoCAD Drawing Management & Output
    Last Post: 4th Sep 2007, 04:15 pm
Tags for this Thread
