Results 1 to 9 of 9
    Senior Member
    AutoCAD 2011
    Feb 2013
    Canada
    115
    Default AutoCAD 3D vs Revit for Structural Plans and Renderings
    I have extensive experience with AutoCAD - but I would like to start learning/using Revit. The majority of use would be for residential applications.
    From my understanding, Revit is mainly used for floor plans, leaving "space" for building materials, but not placing materials themselves.
    A client has asked for a 3D rendering of a proposed deck on his house (for visualization and "instructions"), as well as orthographic 2D plans to submit for permits. I have done this many times with AutoCAD, but was wondering if this was a task Revit could help expediate.
    Am I better off layering a 3D AutoCAD drawing with all materials sized and placed appropriately, or is this a task Revit would excel at?
    Thank you in advance for any insight and advice.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,138
    Quote Originally Posted by CheSyn View Post
    I don't know where you heard that but it's completely false. You can tie Material to any object you want. Below is a 3D walkthrough that our department created last week, and all the objects and materials were generated in Revit:
    https://www.youtube.com/watch?v=EJfWN4sPZOw
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Senior Member
    AutoCAD 2011
    Feb 2013
    Canada
    115
    Hello Tannar, perhaps I used the wrong terminology. From desrcriptions I've read, Revit will create walls, but will not place studs within walls and drywall on the studs. Closer to my example above, it would not show individual joists. (perhaps your video shows this, but I cannot watch Youtube videos at work)
    If this is not correct, does Revit create any advantage over modelling in AutoCAD (ie: time, ease, etc...), specifically pertaining to my needs above?
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,138
    Revit creates walls. AutoCAD does NOT create walls. Revit can be used for wood framing within walls by using Parts, or you can use Structural Framing Families to generate a stud framing system within walls. Since AutoCAD doesn't have "walls", it can't compare directly. And in the AEC industry, Revit is completely advantageous above and beyond AutoCAD. It's not even fair to compare them.
    What's the source that you're getting this questionable information from?
  5. #5
    Senior Member
    AutoCAD 2011
    Feb 2013
    Canada
    115
    I see! I was creating solids and piecing them together to create "walls" and various other structures in AutoCAD, which was extremely tedious (especially when revisions were needed).
    I found information on various forum and blog posts, and Youtube videos. Obviously the information was incorrect. Thank you for clarifying.
  6. #6
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,138
    You mentioned the key word here.... "revisions". You do understand that the term "Revit" is short for "Revise It", correct? This is one of the main philosophies of using Revit over AutoCAD. Revit is parametric... you can change a simple value to make edits or changes later. AutoCAD.... ugh... don't even get me started.
    Well, the information isn't necessarily incorrect, it's just that Revit, right out of the box, doesn't "auto-magically" place stud-wall framing inside the Wall Family. You still have to apply effort in doing this, but when compared to AutoCAD it's 100% night and day in terms of accuracy and efficiency.
    There is even a framing add-on, and it works fantastic, but it comes with a hefty price tag. So if you work for a framing company it'd be worth proposing it to uppers for budgeting for it, but if not, Revit is more than capable of producing stud-wall framing with walls.
  7. #7
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Quote Originally Posted by tzframpton View Post
    "Revit" is short for "Revise It")
    For a while, I thought this was so silly that it could not be true. It has the feel of an urban myth but it's on Wikipedia. So, it must be true.
    Drafting is a breeze.
  8. #8
    Senior Member
    AutoCAD 2011
    Feb 2013
    Canada
    115
    Call me "scared of change"
    I was comfortable with AutoCAD, so I never saw a need to change. The increased demand for 3D renderings forced my hand.
    I toyed with it for a few hours last night and was able to draw my plans. The only issue I came across was for a framing detail where the face of a joist meets a beam at a 45D angle. In CAD I would just slice the solid to create a 45D face. Looking online, it appears I can either use "Opening by Face" or "Cut Geometry" when working with beams in Revit.
  9. #9
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,138
    Call me "scared of change" I was comfortable with AutoCAD, so I never saw a need to change. The increased demand for 3D renderings forced my hand.
    I understand. We all want to stick with what we're used to. Sometimes we forget that what we're used to took lots of time and investment to get where we are today. When moving to a new CAD platform, you lose years of time investment but trust me it's for the better.
    Correct. You can also use Reference Planes to "slice" a beam at any angle you desire with the Cut tool.
  1. Revit Wall and Structural Dimension
    By nicolas in forum Revit General
    Last Post: 4th Feb 2014, 03:47 pm
  2. Replies: 13
    Last Post: 9th May 2013, 08:53 pm
  3. Loading PDF plans onto Revit MEP
    By Plumber man in forum Revit General
    Last Post: 23rd Nov 2011, 01:05 am
  4. Switching from AutoCAD to Revit Structural and MEP
    By RMalloy in forum Revit General
    Last Post: 9th Nov 2011, 08:37 pm
  5. structural plans
    By jeanm315 in forum AutoCAD Drawing Management & Output
    Last Post: 8th Apr 2005, 12:12 am
Tags for this Thread
