Results 1 to 9 of 9
    Forum Newbie cartographer's Avatar
    cartographer's Computer Details
    Win 7
    Dell
    i5 3550 3.3
    20
    Surveying
    AutoCAD 2007
    Sep 2013
    Wexford, Ireland
    8
    Default How to plot viewport without LWT ?
    I'm working on a drawing in AutoCAD 2007 , where final document will have several viewports - one of them should have no Line weight values. Any ideas guys ?
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    If you expand the PLOT dialog (check the round button with an arrow on bottom-right corner) there were two options Plot object lineweights and Plot with plot styles; if you uncheck those then you should get the expected result.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Win 7
    Dell
    i5 3550 3.3
    20
    Surveying
    AutoCAD 2007
    Sep 2013
    Wexford, Ireland
    8
    Multsumesk I'll check it straight away !
    Win 7
    Dell
    i5 3550 3.3
    20
    Surveying
    AutoCAD 2007
    Sep 2013
    Wexford, Ireland
    8
    Unfortunately that does not help.... cant see the icon ;/
  5. #5
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    If you were talking about the button to expose the plot extra options, you should first call the PLOT command and will find it in dialog's bottom-right corner.
    Regards,
    Mircea
  6. #6
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    I'm pretty sure it cannot be easily done in 2007. After 2007, those layer properties can be changed per viewport.
    You could make a copy of the part that needs to plotted and use different layers.
    I would XREF the the part that needs to be plotted differently according to viewport. You would need two references named differently in the plot file. Insert one and rename it. Insert the other one. You now have different layers for each XREF instance. Change the layer settings so that it will plot as desired. VISRETAIN will need to set to 1 to hold the layer settings assigned in the plot file.
    Drafting is a breeze.
  7. #7
    Win 7
    Dell
    i5 3550 3.3
    20
    Surveying
    AutoCAD 2007
    Sep 2013
    Wexford, Ireland
    8
    I'll try that Rob - unfortunately my biggest problem is access to 2007 version of CAD only, options available listed in plot I present on picture below:
    The part that needs to be ploted (vieport) is just a different view of other viewport that I need LWT on. Copy however shall help indeed (weird - I never thought of simplest solution)
  8. #8
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Click here to expand your plot options.
    What do you mean by "...problem is access to 2007 version of CAD only?"
  9. #9
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Later versions have control of layer properties/viewport.
  1. Viewport plot scale @ A3
    By richard3009 in forum AutoCAD Drawing Management & Output
    Last Post: 11th Jun 2014, 07:28 am
  2. viewport is visible in a plot
    By Openantics in forum AutoCAD Beginners' Area
    Last Post: 1st Aug 2011, 09:17 am
  3. Plot from inside a Viewport
    By bamaman83 in forum AutoCAD General
    Last Post: 25th Sep 2009, 04:43 pm
  4. viewport lines on plot
    By bassam001 in forum AutoCAD Beginners' Area
    Last Post: 20th Nov 2008, 02:37 am
  5. The Viewport Wont Plot - Please Help
    By Splicegirl in forum AutoCAD Beginners' Area
    Last Post: 22nd Oct 2006, 10:38 pm
Tags for this Thread
