need help with count list if list mach
plecs
Can someone help me with count list if they are the same
I list that I need count list if they are the same
Thanks in advance
(("123" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0")
("122" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0")
("122" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0")
("12" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0")
("223" "0" "0" "Hz" "0" "0" "0" "0" "ss" "0")
("223" "0" "0" "Hz" "0" "0" "0" "0" "ss" "0"))
i'm not sure but can try
Express tool :acetutil
([color="red"]acet-list-remove-duplicates[/color]
'(("123" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0")
[color="red"]0[/color]
or
For code learning
try this could help?
Unique&Duplicate
thank you,
goes well but how to count lists are identical
I'm not very clear about identical,
Maybe you can try these functions to test the list
Vl-remove-if Vl-some
Vl-every
You can start test (length lst) compare etc..
(setq l '(("123" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0")
(foreach x l
 (if (setq a (assoc x lst))
   (setq lst (subst (cons x (1+ (cdr a))) a lst))
   (setq lst (cons (cons x 1) lst))
You can use my Count Items functions from here:
_$ (LM:countitems l)
   (("123" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0") . 2)
   (("122" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0") . 1)
   (("122" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") . 2)
   (("12"  "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") . 4)
   (("223" "0" "0" "Hz" "0" "0" "0" "0" "ss" "0") . 3)
As hanhphuc has kindly recommended:
Unique&Duplicate
