Results 1 to 6 of 6
    Full Member
    AutoCAD 2014
    Nov 2012
    London, England
    25
    Default Draw rectangle from centre line
    I have a drawing with lots of lines approx. 300mm long. Each of these lines is the centreline of a rectangle that is 20mm wide and the same length as the line.
    So my CAD exercise is to offset the centreline 10mm in each direction and then connect the end points of these new lines to create a rectangle. And repeat several hundred times!
    I know that a lisp routine should be able to do this for me and that it probably involves polar coordinates, but I am at a loss at how to do it.
    Can anyone help?
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,226
    Quickly done
    Code:
    (defun c:Test (/ ss i e 1p 2p a d p1 p2 p3 p4 _line)
      (defun _line (q p)
        (entmakex (list '(0 . "LINE") (cons 10 q) (cons 11 p)))
      (if (setq ss (ssget "_:L" '((0 . "LINE"))))
          (setq e  (entget (ssname ss (setq i (1- i))))
                1p (cdr (assoc 10 e))
                2p (cdr (assoc 11 e))
                a  (angle 1p 2p)
                d  (distance 1p 2p)
          (setq p1 (polar 1p (+ a (* pi 0.5)) 10.)
                p2 (polar p1 a d)
                p3 (polar 1p (+ a (* pi 1.5)) 10.)
                p4 (polar p3 a d)
          (mapcar '_line
                  (list p1 p2 p4 p3)
                  (list p2 p4 p3 p1)
    Full Member
    AutoCAD 2014
    Nov 2012
    London, England
    25
    That's brilliant Tharwat, exactly what I need, thank you.
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,572
    Here's another way, using some trans trickery:
    Code:
    (defun c:l2r ( / i e l n p q s )
        (if (setq s (ssget '((0 . "LINE"))))
            (repeat (setq i (sslength s))
                (setq e (entget (ssname s (setq i (1- i))))
                      q (cdr (assoc 11 e))
                      n (mapcar '- p q)
                      l (mapcar
                           '(lambda ( x )
                                (mapcar '(lambda ( y ) (mapcar x (trans y 0 n) '(10 0 0)))
                                    (list p q)
                (entmake
                    (append
                       '(   (000 . "LWPOLYLINE")
                            (100 . "AcDbEntity")
                            (100 . "AcDbPolyline")
                            (090 . 4)
                            (070 . 1)
                        (mapcar '(lambda ( x ) (cons 10 (trans x n 0))) (append (car l) (reverse (cadr l))))
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,572
    And another, using matrix math:
    Code:
    (defun c:l2r ( / a d e i p q s )
                      a (angle    p q)
                      d (distance p q)
                (entmake
                    (append
                            (090 . 4)
                            (070 . 1)
                        (   (lambda ( m )
                                (mapcar '(lambda ( x ) (cons 10 (mapcar '+ p (mapcar '(lambda ( y ) (apply '+ (mapcar '* y x))) m))))
                                        (0.0 -0.5)
                                        (1.0 -0.5)
                                        (1.0  0.5)
                                        (0.0  0.5)
                            (list
                                (list (* (cos a) d) (* (sin a) -20.0))
                                (list (* (sin a) d) (* (cos a)  20.0))
  6. #6
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,226
    Quote Originally Posted by robertbon View Post
    You're welcome .
  1. Draw rectangle
    By spiker7221 in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Aug 2013, 02:23 pm
  2. Draw a rectangle on a Block
    By rodrigo_sjc_sp in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Apr 2013, 02:38 pm
  3. Replies: 2
    Last Post: 4th Oct 2010, 12:16 pm
  4. How to accurately draw a rectangle ?
    By JamFam in forum AutoCAD Beginners' Area
    Last Post: 11th Apr 2006, 07:47 pm
  5. Draw Rectangle by Area
    By Brunello19 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Nov 2005, 04:50 am
