MEPGuy Posted November 10, 2014 Share Posted November 10, 2014 Hi, The wording in my subject line is probable not the greatest. What I am trying to describe is I have run across customized blocks that when you click on them have a little drop down menu beside them. When you click on the menu the block will actually change depending on what you select. I am creating blocks for various valve fitting symbols and thought this feature might be really useful so rather than dragging all sorts of different blocks around a drawing I could use a single block that has say a ball, gate, butterfly valve etc. sort of built in. Does anyone know what commend you use, or what parameters to define in the block editor to do this? Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
ketxu Posted November 11, 2014 Share Posted November 11, 2014 Oh, you can find what you want with "Visibility Dynamic Block" keyword. HTH ^^ Quote Link to comment Share on other sites More sharing options...
MEPGuy Posted November 11, 2014 Author Share Posted November 11, 2014 Ok I'll give that a try. Thanks Ketxu Quote Link to comment Share on other sites More sharing options...
