Results 1 to 3 of 3
    Full Member
    dal-designs's Computer Details
    Windows 7
    HP Compaq Elite 8300 SFF
    Construction
    dal-designs's Discipline Details
    Designer in Oil and Gas Industry
    Construction
    facilities planning (retail/wholesale fuels and chemicals) aerial surveying and GIS mapping; building design, facilities planning, land development
    AutoCAD 2015
    Feb 2014
    Victoria, Texas
    54
    Question Multileader with non-rectangular text border?
    I'm wondering if there is a way that you can have a non-rectangular border (circle, ellipse, hex, etc) around text in a multileader. I only see an option for a default rectangular border under multileader options.
    I tried making a multileader with a hex drawn around the text, anchored at the landing by a corner, and then centered the text on the hex by manipulating the landing gap. I then tried WBLOCKing the whole thing into an enhanced attribute. It did not work- the multileader lost all editing / moving ability until I exploded it again.
    Part two if this question: how would one do this if the multileader were to be annotative? Seems to me that even if my WBLOCK idea had worked, the hex or whatever wouldn't have scaled right with the multileader text anyway if the anno scale changed too much...
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,768
    There is an option to connect any block to a new multileader style, in the multilieader create dialog. Make a block of whatever shape you want, with a text attribute, BEFORE making the multileader, then go start a new multileader style, select annotative if you want, and select the option to connect a block to it. You than can pick your new block as the one that will be connected to that particular multileader style. The multileader cannot be in the block itself since, as you saw, the way you have it when the block is saved, is the way it stays.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Full Member
    Windows 7
    Construction
    Construction
    AutoCAD 2015
    Feb 2014
    Victoria, Texas
    54
    Thanks- that is exactly what I did wrong.
    This shouldn't affect the appearance in paperspace, though, right? If my anno scale changes from 1:48 (4.5" high text) to 1:65 (6" high text), the text might look too big for the block in paperspace, but so long as the anno text is set to, say, 3/32" paperspace height it should plot out fine, correct?
    I just want to make sure the text will be bounded by the block at any anno scale using this method.
    Sucking at something is the first step to being kinda good at it
  1. How I can write text and that text cover all area of rectangular ?
    By wanted90 in forum Student Project Questions
    Last Post: 24th Feb 2014, 12:03 pm
  2. Different height of text in Multileader
    By Archer Gorgonite in forum AutoCAD Beginners' Area
    Last Post: 24th Mar 2011, 01:29 pm
  3. Multileader text
    By alijahed in forum AutoCAD General
    Last Post: 2nd Mar 2009, 09:58 am
  4. MultiLeader text frame
    By lpseifert in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Jun 2008, 04:49 pm
  5. Border text
    By andy johnson in forum AutoCAD Drawing Management & Output
    Last Post: 30th Oct 2007, 11:13 am
Tags for this Thread
