select hidden features for constraint
albroswift
Hello, All
Just downloaded trial ver of 2015 (as win8.1 upgrade incapacitated my earlier version) trying to select a back edge (or face) of a 3d solid for a constraint and even in wireframe view this will not happen. I can see back edge but cannot select. I don't want to have to rotate around to the back (or view where I see the 2 faces, edges, etc I want to constrain), seemed like in earlier version this was an option, any idea what setting might control this?
Asus X
Win 8.1
Inventor 2015
Thanks--
Al
  • 2 weeks later...
Hello, Lazer
Happy Thanksgiving. Didn't think I was ever going to get a response!
As you mentioned, I can select a face, and then rt click select other, and get the back face. Don't seem to be able to do that to select edge however. I can select a visible edge, rt click, get options for different faces, but not back edge.
Tried to upload image, try again
Image shows up when using explorer, but not with chrome, so, i guess if you want to see exactly what I am referring to, view this forum with explorer!
Thanks--
Al
Edited by albroswift
Image not working
  • 2 weeks later...
Thanks, JD
Your question "What Selection Filter..." pointed me in the right direction, although I don't actually come across a selection filter pull down or list I did find settings through Tools>Application Options>General>selection If there is a more complete filter setting screen I would appreciate a point in the right direction. After deselecting "Enable Optimized Selection" the shift key is now allowing me to select (other) hidden features. (Unless I inadvertently changed something else as well...)
