Sengna Posted November 13, 2014 Share Posted November 13, 2014 Does anybody know which tool to use for what i want to do? I want to enclose this end of this part (see pic below), so that when i finish, i should have close end like very bottom picture (close red area). Should i start new skect and extrude it to close? I have a gut feeling that draft tool would give me what i need for this senario but i still play with this tool, please give me some suggestion. Thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 13, 2014 Share Posted November 13, 2014 Set your UCS to match the 3 points that appear square on the end then draw a closed pline and extrude say sheet metal thick 0.5mm then UCS W etc. Quote Link to comment Share on other sites More sharing options...
Sengna Posted November 14, 2014 Author Share Posted November 14, 2014 Set your UCS to match the 3 points that appear square on the end then draw a closed pline and extrude say sheet metal thick 0.5mm then UCS W etc. How do i set the UCS? Quote Link to comment Share on other sites More sharing options...
gbradley Posted November 14, 2014 Share Posted November 14, 2014 Right Click on this face and Create New Sketch Quote Link to comment Share on other sites More sharing options...
resullins Posted November 14, 2014 Share Posted November 14, 2014 I always use the _ucs command, and then the _3 option. The it will ask you to select three points to set your new UCS: the origin, a point on the X Axis, and a point on the Y Axis. I'e never seen the "Create New Sketch" button that gbradley is showing you... but if you have it, that may be an easier option. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted November 15, 2014 Share Posted November 15, 2014 Sengna, your profile says you are using Autocad 2010, did you mean to post this in the INVENTOR forum? Perhaps your profile needs to be updated, if you are now using Inventor. If not, perhaps a moderator can move this to a more appropriate forum? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 17, 2014 Share Posted November 17, 2014 It is in the Inventor Forum and always has been in the Inventor Forum AFAIK. Quote Link to comment Share on other sites More sharing options...
Sengna Posted November 17, 2014 Author Share Posted November 17, 2014 Right Click on this face and Create New Sketch OK, i will give that a try. thanks Quote Link to comment Share on other sites More sharing options...
Sengna Posted November 17, 2014 Author Share Posted November 17, 2014 Sengna, your profile says you are using Autocad 2010, did you mean to post this in the INVENTOR forum?Perhaps your profile needs to be updated, if you are now using Inventor. If not, perhaps a moderator can move this to a more appropriate forum? I'm sorry i need to update my profile infomation, I am using Autocad and Inventor 2014 now. Please don't move this post to other forum, this is for inventor. If i post this in Autocad then other will ask me to go post in inventor. Quote Link to comment Share on other sites More sharing options...
Sengna Posted November 17, 2014 Author Share Posted November 17, 2014 I always use the _ucs command, and then the _3 option. The it will ask you to select three points to set your new UCS: the origin, a point on the X Axis, and a point on the Y Axis. I'e never seen the "Create New Sketch" button that gbradley is showing you... but if you have it, that may be an easier option.. Thanks resullin, i will give that a try. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 17, 2014 Share Posted November 17, 2014 resullin's and BIGAL's suggestions were for AutoCAD not Inventor. Quote Link to comment Share on other sites More sharing options...
Sengna Posted November 18, 2014 Author Share Posted November 18, 2014 resullin's and BIGAL's suggestions were for AutoCAD not Inventor. Oh, no!!! That's not going to work for me then, this drawing was drawn by inventor. Quote Link to comment Share on other sites More sharing options...
Sengna Posted November 18, 2014 Author Share Posted November 18, 2014 Right Click on this face and Create New Sketch gbradley, if i want to creat a new sketch, should i sketch on "A" surface though not "B", i want about 2" thick of enclosed. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted November 18, 2014 Share Posted November 18, 2014 (edited) resullin's and BIGAL's suggestions were for AutoCAD not Inventor. Which was why I sought clarification on the software used by the OP, in my previous post, and my intention was, that should it actually have been an Autocad question, it might have been better moved to another forum. Now that we are sure it is an Inventor question, clearly it is in the right forum. Edited November 18, 2014 by Dadgad Quote Link to comment Share on other sites More sharing options...
gbradley Posted November 18, 2014 Share Posted November 18, 2014 gbradley, if i want to creat a new sketch, should i sketch on "A" surface though not "B", i want about 2" thick of enclosed. Your choice. You can build the sketch on either plane and extrude it how you like. I would choose the the plane you have marked "B" Quote Link to comment Share on other sites More sharing options...
