danielk Posted November 17, 2014 Share Posted November 17, 2014 Hello is there a fast way to use parts i download from vendor (like parts coming from traceparts.com) that comes as assembly but i want to use as one part? i have thousands of those parts but they all come as small assembly , a thing that make my real assembly slow. i know the derive option , but in this case ill have to do it one by one and its not really efficient Thanks ! Quote Link to comment Share on other sites More sharing options...
Lazer Posted November 26, 2014 Share Posted November 26, 2014 You could use Simplify to break down the parts but again this will not speed up process sadly. Quote Link to comment Share on other sites More sharing options...
lulumara Posted November 26, 2014 Share Posted November 26, 2014 Best way are two simple command--1. Under assembly / Component/ Shrinkwrap and 2. Level of detail/right click on it , on level on detail/ new subtitutes/ derive assembly Just follow what the dialog box then you will arrive to Part that you need. Good Luck! Quote Link to comment Share on other sites More sharing options...
danielk Posted November 27, 2014 Author Share Posted November 27, 2014 Best way are two simple command--1. Under assembly / Component/ Shrinkwrap and 2. Level of detail/right click on it , on level on detail/ new subtitutes/ derive assembly Just follow what the dialog box then you will arrive to Part that you need. Good Luck! where is "level of detail"? Quote Link to comment Share on other sites More sharing options...
Lazer Posted November 27, 2014 Share Posted November 27, 2014 where is "level of detail"? Top left hand side on the tree,open View:Master (above Origin) Quote Link to comment Share on other sites More sharing options...
danielk Posted November 29, 2014 Author Share Posted November 29, 2014 Top left hand side on the tree,open View:Master (above Origin) so its two different methods? not realted to each other .just want to make sure (im new to this ) Thanks! Quote Link to comment Share on other sites More sharing options...
