dan_m Posted November 18, 2014 Share Posted November 18, 2014 Hello all. My modelspace background color is dark grey 33,40,48 and my paperspace is white. Is there a way to set acad up so that when I draw fill colors at 33,40,48 in modelspace they draw as white inside a viewport in paperspace? Quote Link to comment Share on other sites More sharing options...
nestly Posted November 18, 2014 Share Posted November 18, 2014 Am I correct to assume the goal is to create a mask/wipeout that masks regardless of the drawing background color? Quote Link to comment Share on other sites More sharing options...
dan_m Posted November 18, 2014 Author Share Posted November 18, 2014 Not really. I have several filled blocks that I would like to stack one on top of the other. I sort them out using "bring to front" or "bring to back". I switched my modelspace background color to cream and filled the objects in white so I could make out the object contours but ideally I would like to continue working in a dark grey environment and hence the object of my original question. (working in 2D) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 19, 2014 Share Posted November 19, 2014 Config display colors sheet/layout pick colours Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 19, 2014 Share Posted November 19, 2014 Override the color per viewport in Layer Manager. http://www.ellenfinkelstein.com/acadblog/create-layer-overrides-to-create-plot-variations/ Quote Link to comment Share on other sites More sharing options...
Olina Posted November 25, 2014 Share Posted November 25, 2014 (edited) Open CAD, click the Selection tool, select an option in the drop-down box Go to Options settings, click a color This is to enter the background color settings, the settings here are divided into many colors, such as three-dimensional, two-dimensional, the command line, etc., if you are using a three-dimensional drawing or D to select the corresponding Select interface elements into a unified context, the last one in the color bar drop-down to find the color you need, select the application and close dünne ipad air 2 hülle Edited November 28, 2014 by Olina Quote Link to comment Share on other sites More sharing options...
