Results 1 to 8 of 8
    Junior Member
    AutoCAD 2015
    Oct 2014
    12
    Default What am I missing/ did wrong?
    Help would be appreciated.
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    The hidden lines for the holes are missing and the top view shows an unnecessary line indicating a chamfer that doesn't exist on that surface, but my eyes are not good enough to tell much more. If you want a proper critique, upload a better resolution image of the assignment, and attach your actual drawing file.
    Junior Member
    AutoCAD 2015
    Oct 2014
    12
    4-12.jpg105HieuLe4-12.dwg
    here is the better image and the drawing file
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    This is just to prompt you to find corrections.
    I think I am missing one other line.
    If you did this as 3D - you could be sure the solution was correct.
  5. #5
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Something like this.
  6. #6
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    In addition to what JD has already pointed out:
    1) in the side view, you have the 60degree angle beginning at 1.62 from the right edge when it should be 1.45 as you have correctly drawn on the top view. This of course also affects the top of the 60degree angle (green)
    2) There should not be a line between the chamfers on the top view. (yellow)
    3) I believe the (3) chamfers should be .25x.25, not .25 across the face of the chamfer (cyan)
    4) At least one of the R.50 edges should be seen as a hidden line on the top view (magenta)
  7. #7
    Junior Member
    AutoCAD 2015
    Oct 2014
    12
    Thanks for the help guys, I was able to figure everything out. And sorry for the really late reply, I was busy and didn't have the chance to work on it.
  8. #8
    Forum Newbie
    Electrical 2011
    Nov 2014
    3
    i am also a new user ,got the same question.my boss said i can do more detail.thank you for your post.then i knew where i am wrong.
    leder iphone 6 handytasche
  1. PlotStyle - Switch Missing Style to Non-Missing Style
    By cadman6735 in forum AutoCAD Drawing Management & Output
    Last Post: 19th Dec 2012, 06:21 pm
  2. what am I doing wrong??
    By thethirddimension in forum Feedback
    Last Post: 8th Nov 2011, 05:45 pm
  3. Wrong unit or wrong scale?
    By annie26789 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Sep 2010, 07:07 pm
  4. Can someone see where I'm going wrong?
    By Fire_col in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Mar 2010, 02:36 pm
  5. what's wrong?
    By Came in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Mar 2009, 08:29 pm
