Results 1 to 10 of 10
    Full Member
    edoll's Computer Details
    Windows 7
    Dell Optiplex 390
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz 3.40 GHz
    32 GB
    Dual Monitors - An Acer AL2016W and a Acer AL1917W
    AutoCAD LT 2016
    Sep 2012
    Des Moines, IA
    28
    Unhappy Multileader Styles - Right Attachment Attribute not Carrying Over when Applied in DWG
    I am setting up some architectural Multileader Styles to pull into various drawings as needed from the Designcenter.
    I have created 7 different scales of Multileaders and set their Text "Left and Right Attachments" to "Middle of top line". When I pull the styles into a drawing, the "Left Attachment" is true and is at the middle of the top line. However when I make a right attachment the multileader randomly decides to "Underline top line". I have thought of everything I can to try and fix it in the original file referenced from the designcenter...both attachments say "Middle of top line". I have overwrote the Styles in the file and saved things and closed down things and restarted things. lol I'm at a loss and so any help would be appreciated.
    Along the same lines - for these multileader styles I am creating, how can I get rid of default text? I would like to be able to just click the multileader tool, place it in my drawing, and begin typing - but somehow I cannot get rid of the "Contents" - or - "Default Text" because AutoCAD asks me if I want to overwrite the default text when I place it - in which I would always like to overwrite it so i'd rather have no default text and just be able to type asap. lol
    Thanks,
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    If the drawing already contains a Mleader style with the same name, the existing style won't be overwritten.
    I'm not sure about the attachment issue, but it may be related to above... could you upload a sample drawing.
    The default text can be removed by clicking the ellipsis button [...] to the right of the "Default Text" on the MLeader Style manager Contents tab.
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    Quote Originally Posted by nestly View Post
    1+ .... This was my first thought as well, given the OP's 'pulling in' the MLeader Styles.
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
    Full Member
    Windows 7
    Dell Optiplex 390
    32 GB
    AutoCAD LT 2016
    Sep 2012
    Des Moines, IA
    28
    Okay, so I now have the Mleader styles working properly after renaming them and purging the old ones. This also solved the attachment issue. Thanks!
    On another note, I should have explained the "default text thing a little more clearly. I have clicked the [...] and it takes me to my text line where, yes, I can delete the text but when I click out of the text to save it, the text just reappears...
    Is it possible to have Mleader Styles with no text so you can just type a new text from scratch everytime?
  5. #5
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    Quote Originally Posted by edoll View Post
    Okay, so I now have the Mleader styles working properly after renaming them and purging the old ones....
    Glad you got it sorted.
    If you rename things often (i.e., usually for 3rd party drawing, etc.), you might find my Right Click Rename app to be of use.
    With the needed styles already in the drawing, I simply use the MLEADER Command which prompts for text when adding the MLeader to the drawing (no default text specified).
    Cheers
  6. #6
    Full Member
    Windows 7
    Dell Optiplex 390
    32 GB
    AutoCAD LT 2016
    Sep 2012
    Des Moines, IA
    28
    Thanks BlackBox. I would share a screen shot if i knew how, because I am still unable to remove the "content" (default text) of my Multileader style. I click the three dots and remove the text and click away - hoping it will remember that I don't want any "default text" and it just comes right back.
    I use the MLEADER command just as you say, pick leader and landing locations, and then - instead of being able to type what I want - it asks if I want to overwrite the default text. I know this is probably redundant and annoying by now - but there has got to be a way to remove the default text so the MLEADER command performs as it does with ACAD's "Standard" Multileader style.
    if you have an email address - i'd be happy to show you a screen shot i took.
    Thanks,
  7. #7
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    I would share a screen shot if i knew how....
    That may be a minimum post count issue - if memory serves somewhere after 20 posts, you get some new forum features.
    ... I am still unable to remove the "content" (default text) of my Multileader style. I click the three dots and remove the text and click away - hoping it will remember that I don't want any "default text" and it just comes right back.
    In the Multileader Style Manager dialog, select the target style and select Modify button. On the Content tab of the Modify Multileader Style dialog, select the Ellipse [...] button, which will launch the text edit window, select all text (i.e., Ctrl+A), hit the Delete button on your keyboard, then left mouse click in space (outside of the text edit window). You should now be returned to the Modify Multileader Style dialog, and the 'Default text' textbox should read 'Default Text' (which means no default text).
    HTH
  8. #8
    Full Member
    Windows 7
    Dell Optiplex 390
    32 GB
    AutoCAD LT 2016
    Sep 2012
    Des Moines, IA
    28
    Solid Gold BlackBox...solid gold! I'm good to go! I am obviously a beginner and will admit that I did not even think about trying the manager dialog box - thought I could get things done with the properties dialog box only.
    Speaking of 20 minimum posts...
    Thanks for hanging in there with me!
  9. #9
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    No worries, edoll; we all start somewhere... You'll be helping others in no time.
    Congrats on your 20th post!
  10. #10
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,106
    Quote Originally Posted by BlackBox View Post
    The only issue for new members (<10 posts) would be Instant Messaging, everything else works fine, external links will need approval.
  1. CopyText.lsp: Copy/Swap Text/MText/Multileader/Attribute Values
    By alanjt in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Mar 2016, 06:09 pm
  2. Modify Multileader Styles: Custom Content Block: LOCATION
    By CivilPrice in forum AutoCAD Beginners' Area
    Last Post: 26th Jun 2013, 12:21 am
  3. Multileader That Inserts An Attribute From A Block
    By rod_smithsr in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jan 2012, 08:37 pm
  4. Autocad 2008 - Multileader Text Styles
    By nycadguy in forum AutoCAD General
    Last Post: 11th Dec 2008, 07:50 pm
  5. Standard Multileader Styles
    By sag in forum AutoCAD Drawing Management & Output
    Last Post: 5th Sep 2007, 07:03 am
Tags for this Thread
