Import command not recognized - C3D 2010
Sasparilla
One of our computers (not on a network) is using AutoCAD C3D 2010. That particular program doesn't recognize the Import command for points and XML files. The command line indicates that the program is searching for the correct AEC command, but then stops. Is there a setting that will fix this?
Have you tried running a repair (Control Panel > Programs > C3D 2010 > Repair) and it that doesn't work, a reinstall?
It sounds like a missing file or perhaps a missing support path. Unfortunately, I don't have a list of the default stock support paths for C3D 2010.
Maybe resetting the profile or switching to a different profile could fix that...?
