Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Full Member DRBJR45's Avatar
    Manufacture
    DRBJR45's Discipline Details
    Manufacture
    ARCHITECTURAL METAL METALS, ORNAMENTAL IRON, PACKAGE DESIGN. LOTS OF SHEET METAL AND CNC, WATER JET, PLASMA AND LASER.
    AutoCAD 2013
    Jan 2011
    PHOENIX ARIZONA USA
    38
    Default Run macro from pgp file
    HI
    Is there a way to run a macro using keyboard shortcut key (acad.pgp)? I would love to add the following to the PGP file if possible.
    I added the following to the DIMLINEAR command button and it works:
    ^C^C-layer;Set;DIMENSIONS;;^C^C_dimlinear\\\\ ^C^C-layer;Set;0;;^C^C
    I found this one that is better than the one i made for the dimlinear button:
    ^C^C_setenv;CURRENTLAYER;$M=$(getvar,CLAYER);CLAYE R;Dim;_dimlinear;\\\
    CLAYER;$M="$(getenv,CURRENTLAYER)";
    Thanks
    DRBJR45
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,036
    Its easier to make lots of little lisp defuns and autoload them or put them on a menu or toolbar.
    Code:
    ; example appload this then type ddd
    ;^C^C-layer;Set;DIMENSIONS;;^C^C_dimlinear\\\\ ^C^C-layer;Set;0;;^C^C
    (defun C:ddd ()
    (setq oldlay  (getvar "clayer"))
    (setvar "clayer" "dimensions")
    (command "_dimlinear" (getpoint) (getpoint)(getstring)(getpoint)) ;  not tested
    (setvar "clayer" oldlay)
    Manufacture
    Manufacture
    AutoCAD 2013
    Jan 2011
    PHOENIX ARIZONA USA
    38
    Thanks,
    Never did have interest in lisp, guess its time. For some reason your example did not work. starts the dimlinear command and changes layer but thats it. I will use this as a starting point in learning some lisp......
    Again, Thanks!
    Quote Originally Posted by BIGAL View Post
    Code:
    (defun C:ddd ()
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,036
    This is revised version with prompts
    Code:
    (defun C:ddd ( / pt1 pt2 pt3 ans)
    (setq pt1 (getpoint "\npick 1st point"))
    (setq pt2 (getpoint "\nPick 2nd point"))
    (setq ans  (getstring "\nEnter H V or A")) ; use initget here
    (setq pt3 (getpoint "\nPick entension pt"))
    (command "_dimlinear" pt pt2 ans pt3 ) ;  not tested
  5. #5
    Manufacture
    Manufacture
    AutoCAD 2013
    Jan 2011
    PHOENIX ARIZONA USA
    38
    BIGAL
    I really appreciate your trying to help. Im sorry to let you know I'm getting this error:
    Command: appload DDD.LSP successfully loaded.
    DDD.LSP was added to the Startup Suite.
    Command: ; error: malformed list on input
    Command:
    Command:
    Command: ddd Unknown command "DDD". Press F1 for help.
    Thanks again
    DRBJR45
  6. #6
    Super Member hmsilva's Avatar
    Multi-disciplinary
    AutoCAD 2016
    Dec 2012
    Cascais, Portugal
    531
    Extra parenthesis
    Code:
    (setq ans  (getstring ("\nEnter H V or A"))
    EDIT: I would suggest something like this
    Code:
    (defun c:ddd (/ clay)
      (setq clay (getvar 'CLAYER))
      (setvar 'CLAYER "DIMENSIONS")
      (command "_.dimlinear")
      (while (> (getvar 'cmdactive) 0)
        (command "\\")
      (setvar 'CLAYER clay)
    Henrique
  7. #7
    Manufacture
    Manufacture
    AutoCAD 2013
    Jan 2011
    PHOENIX ARIZONA USA
    38
    Henrique,
    Works perfectly!
    I'm excited about learning more about lisp, this should help get me started. Take care and thanks.
    Don
  8. #8
    Multi-disciplinary
    AutoCAD 2016
    Dec 2012
    Cascais, Portugal
    531
    You're welcome, Don.
    Glad I could help.
    EDIT: another way so set the layer DIMENSIONS as current, is using the command 'layer', that allows us to set as current even the layer does not exist, or if exist and is locked, or frozen or off,
    i.e.
    Code:
    (command "_.layer" "_U" "DIMENSIONS" "_T" "DIMENSIONS" "_M" "DIMENSIONS" "")
    If the layer does no exist, will prompt an 'No matching layer names found.' but the command proceeds and make the Layer 'DIMENSIONS' current.
    Henrique
  9. #9
    Manufacture
    Manufacture
    AutoCAD 2013
    Jan 2011
    PHOENIX ARIZONA USA
    38
    Henrique,
    Thanks for the tips....Ive found some sites for beginners in LISP. Some of the basics look easy (famous last words!)
    Don
  10. #10
    Multi-disciplinary
    AutoCAD 2016
    Dec 2012
    Cascais, Portugal
    531
    Quote Originally Posted by DRBJR45 View Post
    Don,
    you don't have to look far, try here @ CADTutor
    Henrique
  1. Lisp or macro to select ctb file ?
    By sinnerboy in forum AutoCAD Drawing Management & Output
    Last Post: 29th Sep 2011, 02:47 pm
  2. How to use a relative path in a Macro to run a .lsp file?
    By Alaskachick in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 28th Oct 2010, 10:54 pm
  3. Open file and run lisp - macro
    By mdbdesign in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th May 2010, 08:08 pm
  4. Publish File Contain Macro
    By MR MAN in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Jun 2008, 08:24 am
  5. Macro Button for file opening
    By geoffc in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Aug 2005, 06:41 pm
Tags for this Thread
