Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    Forum Newbie
    AutoCAD 2015
    Nov 2014
    3
    Default PDF export has lines missing
    I'm fairly new to cad, been using it for less than a year but have never had this problem before: when i export a dwg file to pdf not all the lines appear... it is not a layer issue as some of the missing lines are in the same layer as those that are showing up. if you zoom in to the pdf they will appear but i have quality issues when plotting. i don't think it's the drawing because if i use autocad on the windows side of my mac it is fine although appears to be exporting faintly - blacks are more grey in colour. so i am assuming it's some sort of bug on autocad for mac? i had 2014, deleted it and upgraded to 2015 but have the same issue. i've upgraded to yosemite but the drawing was fine after this, it has only happened in the last few days. please help, my final crit is in 2 weeks!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Why do some users immediately assume going nuclear (deleting and replacing a program) is the only option?
    I'm pretty sure the topic of missing lines in a PDF have been discussed here numerous times. Did you try a search of CADTutor for similar threads or look at the bottom of this page where it lists Similar Threads?
    Forum Newbie
    AutoCAD 2015
    Nov 2014
    3
    It wasn't my first attempt at fixing it, it was actually my last in the hopes of it being a bug and that upgrading might fix it. I have searched through multiple threads but nothing worked and also asked the tutors and other older students at my university with no luck.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Here's what you do then. Attach a copy of the DWG file to your next post. Not an image file (jpg or png) but a DWG file. Someone here will take a look at it and perhaps figure out what's going on. We'll also need to see a copy of the ctb or stb plot style you are using.
  5. #5
    Forum Newbie
    AutoCAD 2015
    Nov 2014
    3
    It wont let me upload the DWG file for some reason.. might be too big.. i know it's not very helpful but i've attached a PDF that shows what's happening.. i found a suggestion of saving it as an EPS file and it's fine and like i said it works okay on my windows autocad. would you assume it's just a bug?
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I would not necessarily assume it's a bug.
  7. #7
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Are you using a third party pdf software? AutoCad 2015 has a superior dwg to pdf.pc3 plotter driver, and there is no longer any need for third party pdf creators.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  8. #8
    Forum Newbie
    AutoCAD 2015
    Apr 2015
    5
    Default having the same problem
    did you found a solution ? i'm having the same problem, lines appear only when you zoom A LOT in
  9. #9
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Can you do as ReMark requested of the OP in post #4 and post a .dwg and plot style?
    It may help if you also post some screen shots of what you are seeing.
  10. #10
    Forum Newbie
    AutoCAD 2015
    Apr 2015
    5
    Okay, so here it is. I'm using Mac AutoCad 2015. I've always used it and i've never have this problem. I usually export pdfs from the layout, using a ctb which i cannot attach (invalid file), but it happens when i use black continous lines in 0.00 or 0.05. The result on pdf looks very pale and lots of lines do not appear. As you zoom in, lines begin to appear, and they all appear just at 200% or more...
  1. Lines, Polylines, densify and export
    By dlm13 in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 9th Apr 2013, 03:44 pm
  2. Lines missing in pdf
    By woodworks in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Mar 2012, 11:32 am
  3. EXport lines from drawing to .lin file???
    By goldy2000 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Jun 2009, 04:33 pm
  4. missing lines
    By petesperry in forum AutoCAD General
    Last Post: 28th Sep 2007, 05:10 pm
  5. Missing Lines
    By jgmdpk in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jul 2007, 09:43 pm
Tags for this Thread
