bjenk8100 Posted November 25, 2014 Share Posted November 25, 2014 hello, i went to cui and format is not on my ribbon. i need to edit points a lot. everyone else has format shown except for me. I do know about pdmode any help is appreciated tnx Quote Link to comment Share on other sites More sharing options...
YZ Posted December 1, 2014 Share Posted December 1, 2014 I have never seen the format menu on the ribbon. Is it a tab, like Annotatie, Output or Manage? Did you see Format in your office, or in another office? Perhaps they built one? Or it might be a Workspace from another Suite? You can create a ribbon tab called Format, and then put on it any of the existing AutoCAD commands that you use a lot. You can also add to that ribbon tab any custom commands you write to help with the specific formatting you do often. To get started, go to CUI, expand the Ribbon item in top left hand list, right click on Tabs, and select New Tab. Quote Link to comment Share on other sites More sharing options...
bjenk8100 Posted December 1, 2014 Author Share Posted December 1, 2014 well, Points is in the draw ribbon. Why cant I change what type of point from there? That would be fine. I need the pixel point format. If steel is more than 3/8" our burn table only puts a tiny spot so people know where to drill. THat spot is only applied when the pixel point format is selected. Point style should be acessible somewhere besides knowing or not knowing the command. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 2, 2014 Share Posted December 2, 2014 Did you try resetting your Profile? Did you try a REPAIR of the installation (not the same as an uninstall/reinstall)? The POINT command can be found on the Draw toolbar. You can modify the toolbar and add other commands to it if you wish. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 2, 2014 Share Posted December 2, 2014 Point Style is on the Utilities in the Home Ribbon, but you can put it on whatever Ribbon you desire. http://www.cad-notes.com/exploring-autocad-cui-working-with-ribbon-part-3/ Quote Link to comment Share on other sites More sharing options...
bjenk8100 Posted December 3, 2014 Author Share Posted December 3, 2014 tnx First time using pts. What do most people use them for? Make a snap somewhere? Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 3, 2014 Share Posted December 3, 2014 I guess you are not interested in trying to fix your problem. Have fun playing with your points. Quote Link to comment Share on other sites More sharing options...
bjenk8100 Posted December 3, 2014 Author Share Posted December 3, 2014 well, I fixed it. It is not under format on my pc. It is under utilities. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 4, 2014 Share Posted December 4, 2014 Isn't that where I said it would be? Point Style is on the Utilities in the Home Ribbon Quote Link to comment Share on other sites More sharing options...
bjenk8100 Posted December 4, 2014 Author Share Posted December 4, 2014 yea. i fixed it by finding it. I never use that. Quote Link to comment Share on other sites More sharing options...
