Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Junior Member
    AutoCAD 2015
    Oct 2014
    12
    Default need help on front view and possibly other view
    I am working on the front view and now I don't know what to do.
    Junior Member
    AutoCAD 2015
    Oct 2014
    12
    here is the pdf
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Maybe just work on getting the main body of the object drawn first in all three views then go back an add the rest?
    Use the top and a side views for projecting lines that will help you create the front view. Were you taught this technique?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    See if THIS TUTORIAL helps.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Quote Originally Posted by artemisrpg View Post
    I can see where you might have difficulty with drawing the front view as there is a lot going on with this object. You have both a slanted back and top, the circular objects standing vertically up from the base, and a few holes as well as a couple of slots/notches to contend with.
    You wouldn't happen to have an 3D modeling skills would you? I'd model this as a 3D solid in AutoCAD then extract the necessary views using the Base View command.
  6. #6
    Junior Member
    AutoCAD 2015
    Oct 2014
    12
    Nope, I haven't learn how to do 3D modeling yet. I also tried to make the top and the side view too but it's still not helping me get anywhere with the front view.
  7. #7
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    You are probably going to have to stick with the orthographic projection technique, then. Back in the days of paper & pencil we had no choice. We used to project the width and height of the round objects as rectangles, since inclined they will appear as ellipses or partial ellipses. Once we established the width and height of the temporary rectangles (inclined circles) we'd draw an ellipse into the rectangles later, using a hard plastic ellipse template.
    On paper, we'd only have to make a tick mark where the ellipses hit their respective width and height, but in AutoCad it's much faster to draw a temporary rectangle.
    You should also project the rounded part's center lines too, both horizontal and vertical.
    Do you also have to draw those two rotated auxiliary views?
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  8. #8
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Don't be afraid to draw as many construction (temp) lines as you need.
    I've attached a modified version o your drawing including some ideas to get you out of draftsman's block. You almost have all you need for a three view already. Accuracy and completeness is your problem.
  9. #9
    Junior Member
    AutoCAD 2015
    Oct 2014
    12
    Quote Originally Posted by Dana W View Post
    I do have to draw those 2 views too. I haven't have much experience with auxiliary view yet so I don't know how well I can draw it or if I can even draw it at all. I will check out the file and attempt it once more in a few hour as I don't have access to autocad right now.
  10. #10
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    All the magenta lines I put in are some temporary projection/construction lines, on a new layer just for them. I moved your 45 deg line. It was too close to your existing view. The white lines, of course are eventually going to be edges of the object. They will need trimming, and filleting in places. Always use temporary lines of a completely different and bright color, so it will be easy to differentiate them from your object lines. erase them as soon as it is possible to do so. The less clutter, the eaier it is to visualize what you have to draw yet.
    I only did enough to give you a good idea on how to get your shapes built quickly from the information you have.
    Those other views aren't that hard, really. You have made a good start on the main view, I guess that is the front view, although this particular object doesn't seem to have an obvious front. Check your first view for absolute accuracy. Any mistakes in it will carry over to the other views, using ortho projection.
    Draw the top & end views next. That way, you'll get used to projecting your construction lines across the 45 deg angle if you have to. Then you can figure out what the angles are for projecting the other views.
    A lot of the time, you really won't need to project anything, because you will begin to be able to visualize the object more easily as you draw it, and then you will start laying it out according to the dimensions on the example because you will know more of how to relate the views in the drawing, and the "3D" picture that will be developing in your head. Orthographic projection was developed as a tool to find those relationships between the parts of an object that are not all that easy to visualize. You will find that eventually, it is almost unnecessary to use the method.
    You know, you can rotate your existing views if it makes it easier to have horizontal and vertical projection lines. For instance, if you rotate the front view you have already drawn 60 deg counterclockwise, you can project most of the lines for those Aux views right off of it, straight down, and straight out to the left. Then, you can rotate all three views back clockwise 60 deg around the same base point you used originally to rotate the front view, when you are done.
    That is one advantage AutoCad has over a piece of paper on a drafting board. Try that rotation trick with paper, and it will lead to geometry errors. Once the paper is taped to the board, it can't be moved until you're done, because it will never register completely straight again.
  1. dimensions not visible in front view
    By bleonard in forum AutoCAD General
    Last Post: 10th Aug 2012, 06:51 pm
  2. View Isometric 3D and Its 2D Views( Top, Elevation and front View) !!
    By basiony in forum AutoCAD Beginners' Area
    Last Post: 7th Dec 2010, 04:22 pm
  3. Front View?
    By Alex91 in forum AutoCAD General
    Last Post: 7th Jun 2010, 05:31 pm
  4. convert 3D to front and top view
    By smiles in forum AutoCAD Beginners' Area
    Last Post: 28th Mar 2008, 03:36 pm
  5. getting 2D(Top, Left, Front) view from 3D object
    By alijahed in forum AutoCAD General
    Last Post: 16th Oct 2007, 12:38 am
