motee-z Posted November 26, 2014 Share Posted November 26, 2014 i want to show road edge curbstone as 3d view i have the edge of the road as 3d polyline and the stone to be arrayed as 3d solids so can any one help by autolisp attached dwg and image thanks friends test.dwg Quote Link to comment Share on other sites More sharing options...
Hippe013 Posted November 26, 2014 Share Posted November 26, 2014 I am assuming that you are not using Civil 3D. It has this functionality already built in. Have you looked into the SWEEP command? Native AutoCAD command. regards, Hippe013 Quote Link to comment Share on other sites More sharing options...
motee-z Posted November 26, 2014 Author Share Posted November 26, 2014 yes i don,t use civil3d sweep command gives as i think one object along 3d polyine but if can be done through lisp will be very great Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 1, 2014 Share Posted December 1, 2014 What software are you using? Hard to help with no knowledge of program you are using. Quote Link to comment Share on other sites More sharing options...
motee-z Posted December 1, 2014 Author Share Posted December 1, 2014 i am using autocad 2013 Quote Link to comment Share on other sites More sharing options...
Hippe013 Posted December 1, 2014 Share Posted December 1, 2014 What do you want the lisp to do? You need to be specific in your request. People reading this have no clue as to what you are looking for. regards, hippe013 P.S. SWEEP Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 2, 2014 Share Posted December 2, 2014 You want a block placed repeatedly along a 3d pline yes ? Ie known length. Quote Link to comment Share on other sites More sharing options...
motee-z Posted December 2, 2014 Author Share Posted December 2, 2014 interval must be defined by the user so he can use the proper interval to suit block length Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 3, 2014 Share Posted December 3, 2014 Easy whilst I dont have code you need a "get pts along pline at interval" 1st attemp 2d, 3d a bit harder. Then insert block at scale. Another way try divide block make a block at actual length you will need to work out how many given L/Bl length this is manual but could be lisp. Quote Link to comment Share on other sites More sharing options...
