export data point to excel file
iyant
need help
how do I export the data points XY of CAD using LISP into excel file for example XY.xls
and placed into a specific cell sheet, eg X = Y = cell cell c2 d2
thank you
iyant said:
need help
thank you
The easiest way is to
save as *.csv comma seperated format
then open with excel
example:
;V1.1:  04/12/2014
;PXYZ test.csv saved to dwgprefix
;add numbering PXYZ format
;index i 1+ incremental
;notified by alert
;optional: add Text numbering
;optional: open notepad
;optional: open directory
(vl-load-com)
(defun c:P2F ( / *error* p i ss fn pt )
;hanhphuc 2014
  (defun *error* (msg)
    (if	(not (wcmatch (strcase msg) "*CANCEL*,*EXIT*"))
    (if	p
      (close p)
  (if
    (and
      (setq i  0
	    ss (ssget ":L" '((0 . "POINT")))
	   (setq fn
		  (strcat (getvar "dwgprefix")
			  "PXYZ test.csv") ; rename you file
	   (setq p (open fn "w"))
					;(setq i 0)
      (repeat
	(sslength ss)
	 (lambda (str)
	   (foreach x
		    (setq pt
			   (vlax-get
				 (vlax-ename->vla-object (ssname ss i))
				 'coordinates
	     (setq str (strcat str (rtos x 2) ","))
	   (write-line
       (strcat (itoa (setq i (1+ i))) "," str)
       p)
	(entmakex
	  (list
	    	'(0 . "TEXT")
	     	(cons 1 (itoa i))
		(cons 10 pt)
		(8 . "EXPORTED")
		(cons 40 (getvar 'TEXTSIZE))
      (if p
	(close p)
      (alert
	(strcat
	  "\nSyabas! Saved in \""
	  fn
	  ;"\"\nOK -> \"PXYZ test.csv\" -> Right-Click -> Open With -> EXCEL"
;;;(command "_SHELL" (strcat "explorer \"" (getvar "dwgprefix") "\"")) ;<-- optional
      (vl-cmdf "_START" (strcat "EXCEL \"" fn "\""))
      (startapp "notepad" fn)
      ;; <--optional open as notepad preview
    (alert "\n:-( knp xde POINT ?! ")
As i notice if you are using Land Desktop, not sure this works in LDD? why not using utility export point?
try look at LDD forum
HTH
Edited by hanhphuc
color tags removed
example:
(defun c:TEST (/ *error* p i ss fn)
;hanhphuc 2014
) ;_ end of if
(if p
(close p)
) ;_ end of if
) ;_ end of defun
(if (setq ss (ssget ":L" '((0 . "POINT"))))
(progn (setq p (open (setq fn [color="red"](strcat (getvar "tempprefix") "XY test.csv")[/color])"w")) ; you can change file name
((lambda (str)
(foreach x (vlax-get (vlax-ename->vla-object (ssname ss (setq i (1- i)))) 'coordinates)
(setq str (strcat str (rtos x) ","))
) ;_ end of foreach
(write-line str p)
) ;_ end of lambda
) ;_ end of repeat
) ;_ end of progn
) ;_ end of if
(close p)
(alert (strcat "\nSaved in "fn)) ; <-- notify file name
) ;_ end of defun
HTH
using AC2008 I get the following error from the program:
Select objects:
Error: ActiveX Server returned the error: unknown name: "COORDINATES"
I believe this is a bug somehow undefined ? or is it not available in AC2008?
Try to add (vl-load-com) to the program and test it again .
Tharewat, thanks for the reply, but adding (vl-load-com) did not help the program to execute.
Perhaps others have had success while I am doing something wrong.
(DEFUN C:Exportpnt (/       FILE    FILENAME	       ANS     CNT
	       PT      X       Y       Z       LINE    DESC
	       LINECOUNTER     LINEDATA	       LEN     OSM
 (SETQ OSM (GETVAR "OSMODE"))
 (COMMAND "OSMODE" 0)
 ;; THIS WILL SET THE FILE NAME WE ARE WRITTING TO AS WELL AS CHECK
 ;; TO MAKE SURE THAT WE ARE WRITTING AT THE END OF THE FILE
 (SETQ LINECOUNTER 0)
 (SETQ FILE (GETSTRING "\nNAME OF POINTS FILE TO OPEN:..."))
 (SETQ FILENAME (OPEN FILE "A"))
 (CLOSE FILENAME)
 (SETQ FILENAME (OPEN FILE "R"))
 (WHILE
   (SETQ LINEDATA (READ-LINE FILENAME))
    (SETQ LEN (STRLEN LINEDATA))
    (SETQ LINECOUNTER (+ 1 LINECOUNTER))
 (CLOSE FILENAME)
 (INITGET "Yy Nn")
 (SETQ
   ANS	(GETKWORD "\n ADD DESCRIPTIONS? Yes OR No ?:...")
   CNT	(GETINT "\nENTER NUMBER OF POINTS TO EXPORT:...")
   PT	(GETPOINT "\nSELECT POINT TO EXTRACT:....")
 ;; THIS BEGINS THE REPEAT LOOP TO EXTRACT THE POINT INFORMATION
 (REPEAT CNT
   (IF
     ( = ANS "Yy")
      (SETQ DESC (GETSTRING "\nENTER DESCRIPTION:..."))
   (SETQ
     X		  (RTOS (CAR PT))
     Y		  (RTOS (CADR PT))
     Z		  (RTOS (CADDR PT))
   (IF	(= ANS "Yy")
     (SETQ LINE (STRCAT (ITOA LINECOUNTER) "," Y "," X "," Z "," DESC))
     (SETQ LINE (STRCAT (ITOA LINECOUNTER) "," Y "," X "," Z))
   (WRITE-LINE LINE FILENAME)
   (SETQ PT (GETPOINT "\nSELECT NEXT POINT TO EXTRACT:..."))
 )					;END OF REPEAT LOOP
 (CLOSE FILENAME)
 ;; RESET THE OSNAP MODE
 (COMMAND "OSMODE" OSM)
 (PRINC)
Will save the file in the directory of the DWG
The routine looks for Autocad "Points" if they are in fact LDD Points then it will probably not work, as mentioned above need different code for LDD.
You just click and it will store the XY values, doesn't have to be a cogo point.
Have a go with this program and let me know .
(defun c:Test (/ i s e p o f)
 ;; Tharwat 04.12.2014	;;
 (princ "\n Select points to export coordinates to new excel file ")
 (if (and (setq s (ssget '((0 . "POINT"))))
          (setq f (getfiled "Save to " (getvar 'DWGPREFIX) "csv" 1))
          (setq o (open f "w"))
     (repeat 2 (write-line "" o))
     (repeat (setq i (sslength s))
       (setq e (entget (ssname s (setq i (1- i))))
             p (cdr (assoc 10 e))
       (write-line
         (strcat ";;" (rtos (car p) 2) ";" (rtos (cadr p) 2))
         o
     (close o)
Thanks Tharwat,BIGAL,JSYoung81,stevesfr for assisting thread very appreciated. :thumbsup:
i slept early last night :oops:
sorry. missing (vl-load-com) code updated in post#2
note: this code only Exports acad AcDbPoint, NOT AECC point!
i came across your old thread
AECC_COGO_POINT , should be different method property for LDD & C3D
hi JSYoung81 we meet again :)
yes your code works because it just creates new incremental points, here are similar threads by
Lee
VVA
  • 1 month later...
       (write-line
         o
     (close o)
Tharwat
This code can be changed in order to automatically enter into an excel file that we have to make before?
  • 9 years later...
       (write-line
         o
     (close o)
cad we add z "x,y,z" and layer to this code.
Z is easy, add  (rtos (caddr p) 2) to this line
to be
(strcat ";;" (rtos (car p) 2) ";" (rtos (cadr p) 2) ";" (rtos (caddr p) 2))
Layer you'll need to add something line
(setq lay (cdr (assoc 8 e)) )
maybe in here
             lay (cdr (assoc 8 e)) ;;Layer
and add lay into the (strcat..... ) line above like this:
(strcat ";;" (rtos (car p) 2) ";" (rtos (cadr p) 2) ";" (rtos (caddr p) 2) ";" lay)
  • Thanks 1
