Tjoeker Posted November 30, 2014 Share Posted November 30, 2014 Hello, I'm in my first year of architecture, so I'm new to Autocad. When I print, my solid hatches (on 2 different layers) aren't printed. however, my ANSI 31 hatch (another layer) is printed correctly. In another document I have all the same settings and it prints perfectly. So I think all my settings are correct: -the layers are set printable in the layer properties manager -in the layout I have tested these settings: 2D wireframe, conceptual and legacy hidden, as displayed. (I believe it should be conceptual and legacy hidden?) Should I check other settings? Or is it just that my printer/laptop doesn't want to print this? Edit: forgot to mention that I googled a lot about it, but none of these solutions solved my problem... Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 1, 2014 Share Posted December 1, 2014 Does it appear fine in plot preview? Can you attach the .dwg file? Quote Link to comment Share on other sites More sharing options...
Tjoeker Posted December 1, 2014 Author Share Posted December 1, 2014 I can't do a plot previeuw because the layout has an invalid hardcopy configuration? anyway, here is my dwg file. It was slightly to big, so I had to remove some parts. which is why the 4 viewports at the bottom are empty. As I am belgian, the text is in dutch. if I need to translate anything, just ask (But i don't think it's any problem) 1415_mm14_BrondeelSimon_PlooimodelPlan_CADTUTOR.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 2, 2014 Share Posted December 2, 2014 Changed the grey layer then it works ??? Quote Link to comment Share on other sites More sharing options...
Tjoeker Posted December 2, 2014 Author Share Posted December 2, 2014 What exactly did you change? I put it on another layer, but the output didn't change... Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 2, 2014 Share Posted December 2, 2014 For the invalid hardcopy configuration, set up to plot, then select "Apply to Layout". Then see if you look correct in Plot Preview. Quote Link to comment Share on other sites More sharing options...
Tjoeker Posted December 5, 2014 Author Share Posted December 5, 2014 Ok, I got the plot preview working. (thanks ) the solid hatches don't show up on the preview. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 8, 2014 Share Posted December 8, 2014 You need to select the viewport boundaries then Right-Click>Shade Plot>Wireframe or As Displayed should work. Quote Link to comment Share on other sites More sharing options...
Tjoeker Posted December 8, 2014 Author Share Posted December 8, 2014 Ok, It works. a Huge thank you to everybody who helped. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 8, 2014 Share Posted December 8, 2014 Your welcome! Sorry I didn't get this last week, but for some reason I can't always open drawings/attachments. For now I blame our IT department, but your drawing worked this morning so I was able to take a look. Quote Link to comment Share on other sites More sharing options...
