LISP running only half way in my computer
tazzzz
Hello,
I have a LISP that used to work nice up until this morning when it start working only half way.
This lisp is doing a bunch of tasks:
-select attributes
-asks for scale
-asks for insertion point to insert a table
-creates a table with attributes selected.
Well, now I am able to perform only first 2 tasks and stops when I have to pick a point for insertion.
(; error: Automation Error. Problem in loading application)
Perhaps I change a variable and I don't know.
Any idea?
Thanks.
ps: the same lisp is working ok in all other computers.
Also I noticed another lisp stops short when I need to select a grip for a block.(Unable to interface with ObjectDBX.)
Edited by tazzzz
more info
Are you using -Insert ? If using Insert it will attempt to use the default settings for Insert which can have stuff like scale and insert pt set to predefined which stuffs up your lisp. Do a plain Insert and un reset the values.
See also text and styles that have stuff preset same problem.
Good idea is to post code so others can have a look even if only the bit thats not working if you have privacy problems.
this is the code
(defun C:COUNTATT(/ acapp acol acsp adoc atable attdata attitem atts blkdata blkname blkobj col
       column colwidth  datalist en headers pt row sset swap  tabledata tags total txtheight widths x)
 ;private function
 (defun sum-and-groupby-three (lst / groups res sum tmp)
 (while lst
   (setq tmp        (car lst)
     sum
           (apply '+
              (mapcar 'atoi (mapcar 'cdadr
                  (setq res (vl-remove-if-not
                          '(lambda (a) (and
                                 (eq (cdr (nth 0 a)) (cdr (nth 0 tmp)))
                                 (eq (cdr (nth 1 a)) (cdr (nth 1 tmp)))
                                 (eq (cdr (nth 2 a)) (cdr (nth 2 tmp)))))
                          lst
     groups    (cons (subst (cons "QTY" (itoa sum))(cadr tmp) tmp) groups)
     lst
           (vl-remove-if
             '(lambda (a) (member a res))
             lst
(reverse groups)
;            main part            ;
 (if (setq sset (ssget (list (cons 0 "INSERT") (cons 66 1))))
     (setq tabledata nil
       attdata nil
       attitem nil
     (while (setq en (ssname sset 0))
   (setq blkobj  (vlax-ename->vla-object en)
         blkname (vla-get-effectivename blkobj)
   (setq atts (vlax-invoke blkobj 'getattributes))
   (foreach attobj    atts
         (setq attitem (cons (vla-get-tagstring attobj) (vla-get-textstring attobj)))
         (setq attdata (cons attitem attdata))
   (setq tabledata (cons (reverse attdata) tabledata))
   (setq attdata nil
         attitem nil
   (ssdel en sset)
(setq headers (mapcar 'car (car tabledata))
       tags    headers
(setq tabledata (sum-and-groupby-three tabledata))
(setq tabledata (mapcar '(lambda (x)
                (mapcar 'cdr x)
                 tabledata
     ;; sort by "DES" :
    (setq tabledata (vl-sort   tabledata '(lambda(a b)(< (car a)(car b)))))
     (setq total 0)
     (foreach i datalist (setq total (+ total (cdr i))))
   (initget 6)
 (setq txtheight (getreal "\nSpecify Text height for the table <50>:"))
 (cond ((not txtheight)(setq txtheight 50))) ;<-- text height as for as in your drawing
      (or adoc (setq adoc (vla-get-activedocument (setq acapp (vlax-get-acad-object)))))
     (or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc))))
(setq acCol (vla-GetInterfaceObject acapp(strcat "AutoCAD.AcCmColor." (itoa(atoi(getvar "acadver"))))))
     (setq pt (getpoint "\nSpecify table location:"))
     (setq atable (vla-addtable
            acsp
            (vlax-3d-point pt)
            (+ 2 (length tabledata))
            (length headers)
            (* txtheight 1.2)
            (* txtheight 20)
     (vla-put-regeneratetablesuppressed atable :vlax-true)
      ;; calculate column widths :
     (setq swap (append (list headers) tabledata)
       widths nil)
     (while (car swap)
   (setq column (mapcar 'car swap))
   (setq colwidth (* 1.2 (apply 'max (mapcar 'strlen column))txtheight))
   (setq widths (cons colwidth widths))
   (setq swap (mapcar 'cdr swap)))
     (setq widths (reverse widths))
      ;; set column widths
      (setq col 0)
      (foreach wid widths
        (vla-setcolumnwidth atable col wid)
        (setq col (1+ col))
     (vla-put-horzcellmargin atable (* txtheight 0.5))
     (vla-put-vertcellmargin atable (* txtheight 0.3))
     (vla-setTextheight atable 1 txtheight)
     (vla-setTextheight atable 2 txtheight)
     (vla-setTextheight atable 4 txtheight)
     (vla-setText atable 0 0 "SUMMARY")
     (vla-SetCellAlignment atable 0 0 acMiddleCenter)
           (vla-put-colorindex accol 3)
(vla-setcellcontentcolor atable 0 0 accol)
     (setq col -1)
     (foreach descr headers
   (vla-setText atable 1 (setq col (1+ col)) descr)
   (vla-SetCellAlignment atable 1 col acMiddleCenter)
   (vla-setcellcontentcolor atable 1 col accol)
      (setq row 2)
     (foreach record tabledata
   (setq col 0)
   (foreach item record
     (vla-setText atable row col item)
     (if (= 1 col)
     (vla-SetCellAlignment atable row col acMiddleCenter)
     (vla-setcellcontentcolor atable row col accol)
     (setq col (1+ col))
   (setq row (1+ row))
(vla-put-width atable (apply '+ widths))
     (vla-put-height atable (* 1.2 (vla-get-rows atable)txtheight))
     (vla-put-regeneratetablesuppressed atable :vlax-false)
(if  accol (vlax-release-object accol))
(if  acapp (vlax-release-object acapp))
(prompt "\n\t---\tStart command with COUNTATT\t---\n")
(prin1)
(or (vl-load-com))
Before this 2 lisp stop working I played with this code:
(defun C:SETUP1 ()
    (setvar "BLIPMODE" 0)
    (setvar "CMDECHO" 0)
    (setvar "OSMODE" 0)
    (setq typ "e")
    (setq dcl_id (load_dialog "setup1.dcl"))
    (if (not
          (new_dialog "setup1" dcl_id)
          (exit)
    (set_tile "rb1" "1")
    (action_tile "rb1"
        "(setq typ \"e\")")
    (action_tile "rb2"
        "(setq typ \"a\")")
    (action_tile "rb3"
        "(setq typ \"c\")")
    (action_tile "rb4"
        "(setq typ \"el\")")
    (action_tile "rb5"
        "(setq typ \"b\")")
    (action_tile "cancel"
        "(done_dialog)(setq userclick nil)")
    (action_tile "accept"
        "(done_dialog) (setq userclick T)")
    (start_dialog)
    (unload_dialog dcl_id)
Resetting AutoCAD to its default settings would be as useless as pouring more gasoline (petrol) in your tank to fix a flat tire (tyre).
Try responding to post #5 re: dialog file.
Yes, I just find out. Acad reset is useless.
What can be the cause for those 2 errors and how can I fix them:
1. ;error: Automation error.Problem in loading application (first lisp)
2. Unable to interface with object DBX(second lisp)
This is the code that I tried before those 2 errors and I think is missing from post 5:
setup1 : dialog {
       label = "Initial Drawing Setup";
     : boxed_radio_column {
       label = "Choose Sheet";
       : radio_button {
         label = "&Engineering Sheets";
         key = "rb1";
         value = "1";
       : radio_button {
         label = "&Architectural Sheets";
         key = "rb2";
       : radio_button {
         label = "&Civil Sheets";
         key = "rb3";
       : radio_button {
         label = "&Electrical Sheets";
         key = "rb4";
       : radio_button {
         label = "&Blank Sheets";
         key = "rb5";
       ok_cancel ;
       : paragraph {
      : text_part {
            label = "Designed and Created";
          : text_part {
            label = "by Kenny Ramage";
I made a little modification on the routine , so try it and let me know .
(defun C:COUNTATT (/ acapp acol acsp adoc atable attdata attitem atts
                  blkdata blkname blkobj col column colwidth datalist
                  txtheight widths x
                                       ;private function
   (while lst
     (setq tmp    (car lst)
           sum
                  (apply
                    (mapcar
                      'atoi
                      (mapcar 'cdadr
                                          '(lambda (a)
                                             (and
                                          lst
           groups (cons (subst (cons "QTY" (itoa sum)) (cadr tmp) tmp)
                        groups
           lst
                  (vl-remove-if
                    lst
   (reverse groups)
                                       ;            main part            ;
     (setq tabledata nil
           attdata nil
           attitem nil
       (setq attdata nil
             attitem nil
       (ssdel en sset)
           tags    headers
                                (mapcar 'cdr x)
                             tabledata
     ;; sort by "DES" :
                              '(lambda (a b) (< (car a) (car b)))
     (setq total 0)
     (initget 6)
     (setq txtheight
     (cond ((not txtheight) (setq txtheight 50)))
     (or adoc
     (or acsp
                    acsp
                    (vlax-3d-point pt)
                    (length headers)
                    (* txtheight 1.2)
                    (* txtheight 20)
           widths nil
     (while (car swap)
                         txtheight
     (setq col 0)
     (foreach wid widths
       (setq col (1+ col))
     (vla-setText atable 0 0 "{\\C3;SUMMARY}")
     (setq col -1)
       (vla-setText
         atable
         1
         (setq col (1+ col))
         (strcat "{\\C3;" descr "}")
     (setq row 2)
       (setq col 0)
         (vla-setText atable row col (strcat "{\\C3;" item "}"))
         (if (= 1 col)
         (setq col (1+ col))
       (setq row (1+ row))
     (vla-put-height
       atable
       (* 1.2 (vla-get-rows atable) txtheight)
 (if acapp
(prin1)
(or (vl-load-com))
Thank you so much !!!
Finally is working. Could you please be so kind and explain what you did ?
Do you think something is missing in my autocad ?
Finally is working.
Excellent , You are welcome and I am happy to hear that .
I deleted all related codes to colors and replaced them with another way of coding and that's it ;)
