vertical geometric points elevations as section view data bands
sacprasanna
Hello all,
I created points on an Alignment by Importing ASCII File.(Station, Offset, Elevation format).Like this,
0,-10,104.003
0,-6.7,104.015
0,-4,104.026
0,-1.5,104.045
0,0,104.007
0,2,104.041
0,4.7,104.102
0,8.7,104.152
0,9,104.168
10,-5.6,103.629
10,-4.3,103.598
10,-4,103.449
10,-3.5,103.345
10,-1.4,103.426
10,0,103.463
10,1.7,103.448
10,3.2,103.314
10,7.5,103.29
20,-4.6,103.203
20,-3.8,103.15
20,-3.4,103.076
20,-3,103.097
20,-2.45,103.238
20,-1,103.255
20,0,103.259
20,3.6,103.172
20,4,103.265
Then using surface and sample lines cross sections are generated.
They I need to add above points (those are at ASCII file) elevations and offsets to the section view as data bands.
But I can't figure out how to do it.I can only add elevations at regular intervals.
Really appreciate any help.
Thanks.
Chamara Prasanna
AutoCAD Civil 3D 2015 SP 1
Sri Lanka
Hello BIGAL,
I attached the image.
Need to add elevations and offset of red circled points.
Thanks for reply.
Chamara
If you brought the points in as COGO points, you should be able to project them to your section view group so that they show up in all of the sections along a given alignment. Then you can create a label style that shows offset/elevation, label all points through the section view properties and just drag the labels down so that they appear to be part of the band. There may be an easier way, but I think that's probably the general workflow to accomplish what you're looking for.
  • 3 years later...
On ‎12‎/‎5‎/‎2014 at 9:02 AM, sacprasanna said:
Hello BIGAL,
Thanks for reply.
Chamara
In Section View Properties put the "Weeding" = 0 and you will see the elevations and offset of red circled points. If you want elevations and offset of red circled points ONLY, without any other points,  put "Minnor and Major Interval" a big number, perhaps  greater than the width of section e.g. 500.00m.
