Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: Line Weight
    Forum Newbie
    AutoCAD pre 2000
    Dec 2014
    6
    Default Line Weight
    I'm using AutoCad Release 13. Is there a way to increase line weight? I'm converting my drawings to a .pdf file so that they can be printed at a local printer who doesn't have AutoCad. When they plot my converted files, the lines are barely visible and get less so when the drawing is enlarged. Thanks for your help.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,833
    Release 13? Not sure I can remember back that far.
    Wasn't lineweight handle in the plot file?
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,117
    In release 13, lineweights were handled by associating a colour with a pen number, and then put a pen of the required width in the carousel.
    How are you getting a PDF? If you set up the correct sheet size, then the plot should have lines of the correct width.
    However, if you set up a PDF for an A4 sheet, and then plot it on an A0 sheet, the lines will be thin.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    I'm pretty sure "Plot Styles" were in 13. Don't have time to check right now but a PDF driver wasn't available or it really sucked. There are free options to using such old software that might make you life easier than trying to get what you want out of that dinosaur. Check out Draftsight and Cute PDF.
    Drafting is a breeze.
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,039
    Do the PDFs look correct on your computer screen?
    What program are you using to plot to PDF?
    Are you plotting in color or black and white (monochrome or grayscale)?
  6. #6
    Super Member
    Ski_Me's Computer Details
    DELL (why oh lord must I suffer)
    Electrical
    Ski_Me's Discipline Details
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    638
    It's not a line weight issue. If you take a photograph and zoom in then the image starts to blur and become pixelated. Same thing is happening here. Setup the layout according to what your printed output is to be then convert. You can't enlarge a pdf you can only zoom. Some converted pdf's can adjust their line weight depending on how far they are zoomed in but I don't think R13 can convert that data for pdf's.
  7. #7
    Forum Newbie
    AutoCAD pre 2000
    Dec 2014
    6
    Since R13 doesn't have a pdf file converter, I'm using ZUMAR, a free online .dwg to .pdf converter. The converted files display normally on screen and I can zoom in without losing any clarity. I send the .pdf files to a local printer to print 18x24 C size drawings. The larger prints are sized correctly, have sharp lines, but the lines are washed out and barely visible. I can print them in either B/W or color scaled-to-fit on 8x11 paper on my HP-960c. They are clear and the colors are normal but of course they are not readable. I did find the system variable POLYWID which can be used to change poly line widths so I thought there must be a variable for line widths. I'm just experimenting with this approach to see if I can get it to work. I know I could send my .dwg files to a drafting service and have them use a CAD plotter but this is expensive for the little amount of work I have. My drawings are drawn full size 160' by 120'. Yes I am a dinosaur - been retired for 10 years now. Just willing to try different things. Thanks for all your comments/assistance. If you have any other thoughts, let me know.
  8. #8
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    How strong is your AutoCAD background? Can you verify that "Plot Styles" are or are not available in R13 and that you know how to use them?
    When I don't have a large format printer available for test plots, I plot a part of the drawing at the proper scale.
  9. #9
    Forum Newbie
    AutoCAD pre 2000
    Dec 2014
    6
    Default Line Weights
    Correction - I'm using ZAMZAR to convert .dwg file to .pdf
  10. #10
    Forum Newbie
    AutoCAD pre 2000
    Dec 2014
    6
    Not strong but "Plot Styles" are not available in R13. If I had a plotter, I would have to go into "Options" and then use "Configure" to set it up as an available plotter. I can print a portion of the drawing (zoom in and print the display) as you do without difficulty. Just trying to experiment with the pdf conversion which I think would work if I could just figure out how to increase line weights in R13. Thanks
  1. Help with line weight
    By sparkyuk in forum AutoCAD Beginners' Area
    Last Post: 28th Mar 2013, 10:49 am
  2. line weight
    By bjenk8100 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Oct 2010, 05:57 pm
  3. line weight
    By nowikovs12 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th Apr 2010, 07:17 am
  4. Line weight
    By Marcus in forum AutoCAD Beginners' Area
    Last Post: 23rd Sep 2006, 07:57 am
  5. line weight
    By sentinel in forum AutoCAD Beginners' Area
    Last Post: 20th Jul 2006, 09:01 am
Tags for this Thread
