andrew10 Posted December 11, 2014 Share Posted December 11, 2014 I use .NET and RealDWG to create a drawing. All the dimentions are inserted to Modal Space with dimstyle which was configured by "Scale dimensions to layout". On the drawing we have a layout and I program to change the viewport scale based on the drawing size. The viewport scale works fine but the dimentions does not follow the viewport scale even we setup "Scale dimensions to layout". Basically it makes sense since the dimentions are inserted into Modal Space. Now the users have to double click the layout to entering modal space, then click "update dimension" button to update dimensions after they change layout view port scale. Two questions are below: 1. Can we insert objects to Modal space based on the view port scale (dimstyle has been setup to "Scale dimensions to layout"). 2. Can we program to update dimentions after we change viewport scale (same function as -DIMSTYLE command in AUTOCAD). Any help will be much appreciated Quote Link to comment Share on other sites More sharing options...
