pattyandme Posted December 16, 2014 Share Posted December 16, 2014 I am trying to understand how to access the properties within the dynamic block in order to change material for the blocks. for instance... I have a deck bluster I want to be able to change from several texture options as well as deck material texture options and such. I have a dynamic block for the bluster so [when I change the material in the block editor now] it changes the materials of all the hundreds of blusters in the drawing. I have anywhere from 8 to ten options I would like to access without opening the block editor... but can not understand how to use a lookup for it? Quote Link to comment Share on other sites More sharing options...
vpatterson Posted December 16, 2014 Share Posted December 16, 2014 When you open the block editor it will change all references to that specific block. If you do not want to change all blocks I would recommend you to create a new block. Quote Link to comment Share on other sites More sharing options...
pattyandme Posted December 16, 2014 Author Share Posted December 16, 2014 (edited) I want to change all blocks from outside the editor dynamically, like setting visibility - you don't need to open the editor to change which view you want visible. From what I seen so far there is no action which can change the Materials property from a lookup list. I would either need to make 8 different blocks and set there visibility indexed to the material choice only changes 1 block at a time or set them on there own layer and change the layer material with a lisp ... this is what I found so far still looking for other answers though. seems like a lot of memory use to add 8 to 10 of each items when I only want to change the material which would be through the block editor to eliminate that and that is what im trying to eliminate...when at a customers home I would like to switch optional material views without having to enter the block editor. Thinking about it I wont be able to change the property from dynamic's in the block because it will still copy the full block with the array so I need to look for something external to the block to change the property a command tool or something. Edit the block in place is what I was looking for just didn't know it. Edited December 17, 2014 by pattyandme Quote Link to comment Share on other sites More sharing options...
pattyandme Posted December 16, 2014 Author Share Posted December 16, 2014 Yikes http://www.lee-mac.com/dynamicblockfunctions.html Quote Link to comment Share on other sites More sharing options...
