Results 1 to 6 of 6
    Senior Member
    AutoCAD 2010
    Feb 2014
    129
    Default selection set with point and filters
    I m trying to make a selection set using a point and a couple of lines passing through this point (caution, NOT terminating). I want to select lines of specific layers. What I m typing is this
    Code:
    (setq pt (getpoint "\nSelect point: "))
    (setq ss (ssget pt '((0 . "LINE") (8 . "mylayer"))))
    Unfortunately this doesn't work. The only way I could find is to use this instead
    Code:
    (ssget "C" pt pt '((0 . "LINE") (8 . "mylayer")))
    However I do not find that helpful at all. If there is a line at the back on an other elevation, not crossing the initial line, but coincidentally passing 'visually' through this point (pt) the later ssget command will include both and that is not what I want.
    How could I use a point and filter together? Any help would be appreciated.
    Super Member hmsilva's Avatar
    Multi-disciplinary
    AutoCAD 2016
    Dec 2012
    Cascais, Portugal
    531
    Try
    Code:
    (setq ss (ssget pt (list '(0 . "LINE") '(8 . "mylayer")(cons -4 "*,*,=")(cons 10 (list 0.0 0.0 (caddr pt))))))
    ;; or
    (setq ss (ssget "C" pt pt (list '(0 . "LINE") '(8 . "mylayer")(cons -4 "*,*,=")(cons 10 (list 0.0 0.0 (caddr pt))))))
    Henrique
    Senior Member
    AutoCAD 2010
    Feb 2014
    129
    Thank you. The first one doesn t seem to work. The second works but this way only filtering the Z. If I change the viewpoint of the entire model this will not be reliable. I tried
    Code:
    (setq ss (ssget "C" pt pt (list (cons 0 "LINE") (cons 8 "mylayer") (cons -4 "=,=,=") (cons 10 (list (car pt) (cadr pt) (caddr pt))))))
    but it gives me nil! It should have worked. There is at least one line passing through the pt.
    Multi-disciplinary
    AutoCAD 2016
    Dec 2012
    Cascais, Portugal
    531
    Code:
    (setq pt (getpoint "\nSelect point: "));; your known point
    (setq wpt (trans pt 1 0));; point in WCS
    (setq upt (trans wpt 0 1));; point in actual UCS
    (setq ss (ssget "C" upt upt (list '(0 . "LINE") '(8 . "mylayer")(cons -4 "*,*,=")(cons 10 (list 0.0 0.0 (caddr upt))))))
    HTH
    Henrique
  5. #5
    Senior Member
    AutoCAD 2010
    Feb 2014
    129
    Thanks! I will look into it.
  6. #6
    Multi-disciplinary
    AutoCAD 2016
    Dec 2012
    Cascais, Portugal
    531
    You're welcome!
    Henrique
  1. Question about POINT FILTERS
    By Faouweb in forum AutoCAD 3D Modelling & Rendering
    Last Post: 25th Dec 2011, 10:18 am
  2. Point Selection
    By cadpro in forum .NET, ObjectARX & VBA
    Last Post: 21st Jun 2011, 03:49 am
  3. Point Filters!?
    By mrmanagerr in forum AutoCAD Beginners' Area
    Last Post: 30th Mar 2011, 03:52 pm
  4. Point selection problem
    By KRBeckman in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Feb 2010, 11:57 pm
  5. Selection Set Filters Vlisp
    By nauggie in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Oct 2006, 03:47 pm
Tags for this Thread
