Ramana Posted December 17, 2014 Share Posted December 17, 2014 Hi friends, Greetings I am working on a project where client need the detail of the stone clading work with 1.5mm space the size of the 500x1000 with the space of 1.5mm. I have tried i am getting the the pattern but unable to get the space SOME PROBLEM WITH MY CODE, PLEASE SUGGEST ME... ;%UNITS=MM ;%TYPE=MODEL *CUSTOMESTONE,SAMPLE 90,0,500,0,501.5,1001.5,501.5 0,0,500,349.78,0,501.5,1001.5,501.5 90,0,501.5,-1001.5,500,-1.5 0,0,500,1001.5,501.5,349.78,-651.72 THANKS IN ADVANCE RAMANA Quote Link to comment Share on other sites More sharing options...
hugha Posted December 18, 2014 Share Posted December 18, 2014 Parameter count per line normally should be 7, you have 7/8/6/7 ... Please describe how your 500x1000 tiles are arranged - apart from the 1.5mm gap. Are they stacked or offset? As an example the pattern derived from the screenshot is : ;------------------------------------------------------------------------------- ; Written by HatchKit 2014 Professional ; HatchKit 2014 Professional© Cadro Pty Ltd 1990-2014 ; www.hatchkit.com.au/ ;------------------------------------------------------------------------------- ;-Date : 18/12/2014 ;-Time : 3:38:35 PM ;-HatchKit Version : 3.0.1.2496 ;-HatchKit Output Filetype : Revit with HatchKit Add-In ;-HatchKit Licensed To Name : hugh adamson ;-HatchKit Licensed To Organization : ;-HatchKit SerialNumber : .... ;------------------------------------------------------------------------------- ;%VERSION=3.0 ;%UNITS=MM *RAMANA,HORIZONTAL 1000mmx500mm bond=1/3 ;%TYPE=MODEL 90,0,0,501.5,-333.833333333,500,-1004.5 0,0,500,-333.833333333,-501.5,1000,-1.5 -90,1000,500,501.5,-333.833333333,500,-1004.5 180,1000,0,333.833333333,501.5,1000,-1.5 It's very easy to generate another ... hth, Hugh Adamson Cadro Pty Ltd www.hatchkit.com.au Quote Link to comment Share on other sites More sharing options...
