Ramesh PK Posted December 19, 2014 Share Posted December 19, 2014 Is there any way of aligning one 3D object with other using VBA? Regards, Ramesh.P.K. Quote Link to comment Share on other sites More sharing options...
SEANT Posted December 19, 2014 Share Posted December 19, 2014 VBA would be limited - maybe with just regular Boxes and Cylinders. The BREP API available to ARX/.NET would allow more capabilities. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 21, 2014 Share Posted December 21, 2014 Probably better to look at Inventor I appreciate it does have a cost 2007 upgrade others will comment I don use. Like Seant if you have simple primitives probably possible with VBA. Maybe something like a current UCS compare new UCS and use rotate3d to align then move. Can you post a image of the objects to be religned. Quote Link to comment Share on other sites More sharing options...
RICVBA Posted December 22, 2014 Share Posted December 22, 2014 VBA would be limited - maybe with just regular Boxes and Cylinders. The BREP API available to ARX/.NET would allow more capabilities. I'm trying to mess something up with NET. I use VS2010 and AutoCAD2010 and downloaded the ObjectARX 2010 SDK. but the line [color=blue]using[/color] Autodesk.AutoCAD.BoundaryRepresentation; results in an error. Searching through folders I found .dbx and .arx files referring to BREP but not a .dll file at all. How can I reference BREP NET libraries properly? Am I missing a piece of something? Thank you Quote Link to comment Share on other sites More sharing options...
SEANT Posted December 22, 2014 Share Posted December 22, 2014 Typically, the reference can be found at: .../ObjectARX 2010/inc/acdbmgdbrep.dll Remember to set Copy Local = False Quote Link to comment Share on other sites More sharing options...
RICVBA Posted December 22, 2014 Share Posted December 22, 2014 Typically, the reference can be found at:.../ObjectARX 2010/inc/acdbmgdbrep.dll Remember to set Copy Local = False thank you Seant I'll check your hint this evening Quote Link to comment Share on other sites More sharing options...
RICVBA Posted December 22, 2014 Share Posted December 22, 2014 thank you SeantI'll check your hint this evening that made it! unless the path was "...\AutoCAD 2010\ObjectARX 2010\inc-x64" thank you again Seant Quote Link to comment Share on other sites More sharing options...
