Replace the attribute value
DuanJinHui
Hello! everybody. Merry Christmas!
I've done a little bit of searching for this, but have not found what I've needed.
but would like to know if anyone has come up with a lisp solution.
in modelspace . some attribute block, one attribute tag is "DR_DATE" , I want replace value of this tag .
PS. Not replace all attribute block, only selection area . the new value I need input.
Thanks!
Something like this ?
(defun c:TesT (/ st ss)
 ;; Tharwat 25.12.2014    ;;
 (if (and (/= "" (setq st (getstring t "\n Specify new value :")))
          (princ "\n Select Attributed blocks ...")
          (ssget "_:L" '((0 . "INSERT") (66 . 1)))
   (vlax-for x (setq
                 ss (vla-get-ActiveSelectionSet
                      (vla-get-ActiveDocument (vlax-get-acad-object))
     (mapcar '(lambda (a)
                (if (eq (strcase (vla-get-tagstring a)) "DR_DATE")
                  (vla-put-textstring a st)
             (vlax-invoke x 'getattributes)
 (if ss
   (vla-delete ss)
)(vl-load-com)
   (vlax-for x (setq
 (if ss
   (vla-delete ss)
)(vl-load-com)
Mr.Tharwat. It's good . very very very good! Thank you.
