GemmaEBaird Posted December 26, 2014 Share Posted December 26, 2014 Hi I've created 3 parallel lofts, I want to make them into a solid - is this possible ? If so how ? Thank you Quote Link to comment Share on other sites More sharing options...
lrm Posted December 26, 2014 Share Posted December 26, 2014 Make each of the 3 closed shapes a region then use the loft command. Quote Link to comment Share on other sites More sharing options...
GemmaEBaird Posted December 26, 2014 Author Share Posted December 26, 2014 How do I go about doing that - it is an undulating surface ? Quote Link to comment Share on other sites More sharing options...
nestly Posted December 26, 2014 Share Posted December 26, 2014 A sample drawing containing only the relevant objects would be helpful. ( WBLOCK command makes this easy) Quote Link to comment Share on other sites More sharing options...
GemmaEBaird Posted December 27, 2014 Author Share Posted December 27, 2014 I need to give this 'loft' a thickness of 500mm in the direction of the offset It doesn't seem to want me to upload a dwg though ? Why could that be ? Quote Link to comment Share on other sites More sharing options...
GemmaEBaird Posted December 27, 2014 Author Share Posted December 27, 2014 ok - I cant get it small enough ? Quote Link to comment Share on other sites More sharing options...
lrm Posted December 27, 2014 Share Posted December 27, 2014 Can you post a picture of what you want to model or your AutoCAD file on Dropbox or some other server? Quote Link to comment Share on other sites More sharing options...
GemmaEBaird Posted December 27, 2014 Author Share Posted December 27, 2014 I want to put a roof of 500mm thick on this structure I've made a 'loft' using splines over the structure but it wont et me give it a thickness Quote Link to comment Share on other sites More sharing options...
GemmaEBaird Posted December 27, 2014 Author Share Posted December 27, 2014 this is the surface .............. Quote Link to comment Share on other sites More sharing options...
lrm Posted December 27, 2014 Share Posted December 27, 2014 Use the offset command to create an offset spline for each of the splines before lofting. Add straight lines or a curve at the ends of the splines to form closed shapes. Be careful to be consistent in the way you construct each section (left to right or top to bottom, etc.). Use REGION to convert each closed profile to a region then use loft. Quote Link to comment Share on other sites More sharing options...
GemmaEBaird Posted December 27, 2014 Author Share Posted December 27, 2014 OK I've tried closed 3d polylines - separate 3d polylines - splines. Nothing is working Can anyone help at all ? Upload.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 27, 2014 Share Posted December 27, 2014 Please try to show some patience. Thank you. Quote Link to comment Share on other sites More sharing options...
GemmaEBaird Posted December 27, 2014 Author Share Posted December 27, 2014 ReMark - I wanted to upload a drawing so you could see what I'm trying to do - is this wrong ? Quote Link to comment Share on other sites More sharing options...
lrm Posted December 27, 2014 Share Posted December 27, 2014 (edited) Is your goal to build a solid sculptured surface of constant thickness that lies along the top of the CLT panels in your drawing? If so I suggest using the splines that form the top edge of the panels as a start. Make certain that they lie on a flat plane then create offset splines as I mentioned earlier and convert the closed shapes to regions then loft to form a solid. The image below shows the 3 regions I used to create the solid shape on the right. Edited December 27, 2014 by lrm Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 27, 2014 Share Posted December 27, 2014 ReMark - I wanted to upload a drawing so you could see what I'm trying to do - is this wrong ? No, there is nothing wrong with uploading a drawing which is something I believe you have done in the past. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 29, 2014 Share Posted December 29, 2014 I deleted your other thread, please do not create multiple threads on the same question. Quote Link to comment Share on other sites More sharing options...
GemmaEBaird Posted January 7, 2015 Author Share Posted January 7, 2015 OK this sort of works but I'm getting some strange anomalies .... Quote Link to comment Share on other sites More sharing options...
GemmaEBaird Posted January 7, 2015 Author Share Posted January 7, 2015 OK - I still cant work this out. This is the drawing I want to loft. All of the polylines are closed, created on the same plane and created in the same direction ( top right clockwise ) I can't work out what the issue is - I've re-drawn it 3 x now ?? Loft.dwg Quote Link to comment Share on other sites More sharing options...
lrm Posted January 7, 2015 Share Posted January 7, 2015 GemmaEBaird, it appears that either I was not clear in my instructions or you did not understand them. Your goal should be to build the lofted solid from a series of 2D regions positioned in 3D space. I see no 2D regions in the image you supplied. It looks like you tried to loft a solid by selecting the top of one "rib" and the side of another. The three shapes in the top left corner of my last post are three 2D regions positioned on different planes. Each of the three regions was constructed by creating a single spline. I then used offset to construct another spline offset by a constant distance. Finally, I added a line at each end of the double splines to close off the shape. From this shape I used region and selected the 2 splines and 2 lines. Did you create a region in this manner? Start by creating at least three regions (not solids) and post the file here. Good luck. lrm P.S. I just got your file and will take a look at it. Quote Link to comment Share on other sites More sharing options...
GemmaEBaird Posted January 7, 2015 Author Share Posted January 7, 2015 (edited) No - I have done what you have said - the image just includes another layer - you can see the regions in the CAD I just uploaded OK - Ive done most of it in 'parts' and unioned .... but I cant close the gaps. If you could help that would be AMAZING A slightly different question too ........ can you 'hide' specific lines like you can in sketchup ? ( cant upload the new drawing - it's too big ) Edited January 7, 2015 by GemmaEBaird Quote Link to comment Share on other sites More sharing options...
