Results 1 to 6 of 6
    Full Member
    Architecture 2015
    Jul 2014
    64
    Default TRIM only selected lines
    So I will select certain lines and do the trim command but it will trim any line that I drag the mouse over whether i selected that line to trim or not. Is there a way for it to JUST trim the lines I select and nothing else?
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,501
    Fence option maybe Trim obj F
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    It should not be trimming anything that's not actually picked (or part of a windowed selection). Perhaps COMMANDPREVIEW is misleading you to believe the object(s) are being trimmed, but they're not actually trimmed yet (until they're selected)
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,760
    In my experience any line crossing the selected "fence" will be trimmed IF it is selected, that is clicked on (or windowed) once the trim command is active. The lines to be trimmed do not have to be pre-selected, in fact it is rather pointless to previously select anything but the trimming line or polygon.
    Nestly may be on to something. In AutoCad 2015 the selection preview for trim makes the lines rolled over dissapear almost completely although they are not yet actually trimmed until selected.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  5. #5
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    Win 7, Win 8
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    TN or KY depends if I'm at work or home.
    924
    Try EDGEMODE = 0
    Murph
    Need a boat or camper for the weekend?
  6. #6
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Like nestly said, it shouldn't trim anything unless you select it. Something is not making sense here.
    Can you describe your procedure with some more detail and maybe a screen shot or two?
    Drafting is a breeze.
  1. Trim lines around text - help
    By flopo in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Apr 2018, 09:14 am
  2. How to trim lines on a 3d sketch
    By mattador04 in forum Autodesk Inventor
    Last Post: 16th Jan 2014, 12:29 pm
  3. Trim lines
    By hemal in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Nov 2012, 01:05 pm
  4. Selected lines not appearing on screen as being selected.
    By mrjangles in forum AutoCAD Drawing Management & Output
    Last Post: 17th Feb 2009, 05:42 pm
  5. Trim only trims little lines
    By hyposmurf in forum AutoCAD General
    Last Post: 12th Jul 2004, 01:18 pm
Tags for this Thread
