Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Forum Newbie
    AutoCAD 2015
    Dec 2014
    9
    Default Is there a way to attach PDFs permanently?
    I'm using AutoCad 2015 to convert PDF files into drawings, but every time I access the files on a different computer the PDF is gone. In its place is a message saying "missing or invalid reference", so I have to reattach the PDF. Can I attach the PDF permanently, instead of as a reference? If so, how?
    Thanks in advance for any helpful replies.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,736
    Do the two computers (yours and this other one) share the same network?
    It sounds like a "path" problem to me or you did not copy the PDF over to the other computer and put it in the same folder as the drawing. Do you specify a "full" path when you attach PDF's to drawings?
    Path Type
    Select the full (absolute) path, the relative path to the PDF file, or No Path, and the name of the PDF file. For the No Path option, the PDF file must be located in the same folder as the current drawing file.
    And as far as I know one cannot "convert" a PDF file into a drawing using AutoCAD. While there are PDF to DWG conversion programs available the best one can do in AutoCAD is "attach" a PDF.
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,244
    If you're moving from one location to another, such as going from work to home, use the ETRANSMIT command to create a zip file containing your drawing and all associated xrefs, fonts, image files, etc. Then, once you get to the new location, simply unzip the file to a folder and all your associated files should be there when you open the drawing.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Forum Newbie
    AutoCAD 2015
    Dec 2014
    9
    I guess I worded that pretty poorly. I'm not so much trying to convert the PDFs to drawings, what I'm doing is using the PDFs as underlays and creating the drawings over them. So what I'm basically hoping to do is attach the PDF as a permanent underlay rather than as a reference to a separate file. Is that possible?
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,736
    I don't know of a way to do that unless inserting it as an OLE object is an option with a PDF. Not sure because I studiously avoid the insertion of PDF's in my drawings. Be advised that if it is possible the solution would come with its own sets of problems. You would just be trading one for the other.
  6. #6
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    Southern California
    10,244
    Yes, you can insert a pdf as an OLE object using the INSERTOBJ command. Just run the command and choose "Adobe Acrobat Document" as the Object Type, then click OK and choose your pdf. I've never had much luck with OLE objects though. Always a bit problematic.
    Facebook:
  7. #7
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Quote Originally Posted by Cad64 View Post
    How true that is. I have found that the object image does not change its view size while zooming. In other words, the image stays the same size while the image background/frame zooms in and out. It is simply an unmanageable mess.
    Another way is to convert the pdf to a png image in a photoshop-like program at the absolute highest resolution possible and at actual size (to preserve scale), and then insert the png as a "paintbrush picture". You will then have to scale it up to trace over the image, and this will degrade the resolution somewhat.
    The best way to handle it is to stay with the pdf underlay xref file, and just be sure to copy the xref(s) along with the dwg file any time you transport the dwg outside of its original directory location. Save both the dwg and xref file into the same folder and AutoCad will have no trouble locating the xref. Looking in the same folder first is an Autocad default if it finds the stored file path not workable.
    At least with a pdf underlay xref, if it is a vector pdf, one can actually find lines and things to snap to. I have one of a floor plan from the Amelia Island R*** C****** hotel that I am currently using as a key plan to locate my project installation areas. Since it is only a key plan, I don't have to scale it, simply viewport it at 1:1, and put my page reference call-outs in paperspace. However, I did have to trace a couple of ballroom doorway areas right off this pdf because neither the arch or ID drawings had an enlarged plan view of the areas. I traced while snapping to the vector lines in the pdf, then scaled my lines up from 1/16" = 1'-0" to full size. It was only an inch or two off the eventual field dimensions I got, so good enough for indicating a crown, wainscot & chair rail reno in plan view for my shop drawings.
    Reno project plans are always terrible. Designer types forget that we all cannot BE THERE to conceptualize what is going on.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  8. #8
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    Southern California
    10,244
    I stick with my original suggestion.
    1. Run Etransmit command and create Zip file
    2. Move to new computer and extract all files to new folder
    3. Open Autocad and continue working
    Simple
    Facebook:
  9. #9
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Simple
    Agree. The point is to take the xref and the drawing with you.
  10. #10
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,160
    We make sure all pdf's jpg's etc are in the same location as the dwg you are opening running on a server network this way they are found automatically. Its annoying when we get Can't find C:\jpgs\jpg123xxxx thats a quick yell across the room move your JPG. But like all the other suggestions once off the server they must all be together.
  1. How do I permanently attach materials & textures to objects
    By ajac63 in forum UVW Mapping, Textures & Materials
    Last Post: 7th Dec 2013, 08:02 pm
  2. unable to attach PDFs as XREFs
    By klrqn in forum AutoCAD General
    Last Post: 10th Apr 2013, 08:24 pm
  3. change 3D mode to 2D permanently
    By khoshravan in forum AutoCAD Beginners' Area
    Last Post: 6th Jul 2010, 03:12 am
  4. Turning off the grid permanently
    By gofindsam in forum AutoCAD General
    Last Post: 9th Jun 2010, 07:34 am
  5. how to keep suffix simbol permanently
    By tem in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Sep 2008, 10:34 am
Tags for this Thread
