Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Junior Member
    Construction
    dueingx4's Discipline Details
    Architectural Consultant @ Crown C Supply
    Construction
    AutoCAD 2012
    Jan 2013
    St. Louis, Missouri
    22
    Default Simple question, so apologies if it's too simple!
    I have CAD files I want to take home on a thumb drive. When I get home and open up any folder with an xref in it, the xref does not show up. When I try to alter the path, it goes back to looking for the folder where the file is located at my office.
    Anybody have thoughts on this one?
    Thanks!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    You should have used the eTransmit command.
    Package and deliver groups of drawings and related and supporting files in electronic transmittal packages. Packages can be created as:
    1) a file folder
    2) ZIP file
    Junior Member
    Construction
    Construction
    AutoCAD 2012
    Jan 2013
    St. Louis, Missouri
    22
    Remark: thanks for the reply so fast! I will execute that command, but curious, can it be for a specific sheet, or does it do the whole directory of drawings?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    The ETRANSMIT command pulls together all files that the drawing file depends on.
  5. #5
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    You could also simply copy the cross referenced file along with the drawing using it, and save them to the same folder on your home computer. AutoCad always looks in the same folder with the drawing first if it does not have a workable path to use.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  6. #6
    Junior Member
    Construction
    Construction
    AutoCAD 2012
    Jan 2013
    St. Louis, Missouri
    22
    Dana:
    I copied all files, xref's and sheets, onto my desktop at home in a seperate folder. I'm confused on why AutoCAD could not relocate the xref's as I tried to change the path in the xref box... It seemed like it was not willing to have the original path drive altered, it would go right back to the "T" drive that was at work... sounds like etransmit will work properly, but how will it do when I want to take the files back to the office, will that screw anything up?
    Thanks!
  7. #7
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    I am not sure what you are saying. Did AutoCad not find the xref file when you opened the drawing, or are you just trying to update the path in the xref manager dialog?
    I recommend saving your autocad files to any other folder rather than the "desktop". All the shortcuts on there can make AutoCad get its knickers in a wad while it is trying to figure out where it is supposed to be looking for stuff.
    AutoCad does not automatically update the saved path for the xref file. As long as the program can find the xref when the drawing is opened (ie. both in the same folder) then leave the saved path the way it was so you don't have to change it when you take the drawing back to work.
    I don't update my saved path unless I have to. I caught a lot of snot from the Drafting Project manager once when I had to use my daughter's laptop as a backup work machine. Her somewhat off color user name did not sit well with that guy at all when it showed up in the plot stamp.
    Anyway, to update the saved path, open the xref manager dialog and click on the xref name in the file list, then click on the saved path line in the details area, then either navigate to the xref file location by hitting the browse button at the end of that line, or by manually typing in the path.
  8. #8
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,316
    Quote Originally Posted by dueingx4 View Post
    This is why Etransmit is such a great tool. It not only bundles up your drawing and all associated xrefs and image files, but it also grabs all fonts used in the drawing, plot styles and pretty much everything you need in order for your drawing to work on any computer you put it on. And it's all automatic and takes only a few seconds. You don't have to manually go digging around searching for files or worry that you might accidentally forget something. And when you extract the zip file to a folder, Autocad knows where to look for the files. No need to repath anything.
    This is where you have to be diligent with your file management. If you take files home to work on them, when you bring them back to the office you will need to move the existing, and now obsolete, files to a backup folder and then replace them with the updated files.
    Note: If you do need to repath xrefs, you can use the Reference Manager utility found in your Start Menu > All Programs > Autodesk > Autocad "Version Number". It allows you to easily repath all xref files with just a few mouse clicks.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  9. #9
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
  10. #10
    Junior Member
    Construction
    Construction
    AutoCAD 2012
    Jan 2013
    St. Louis, Missouri
    22
    OK, here is the deal... I brought files home originally just bringing all drawing files and xref files home. Copy them off my thumb drive onto a folder on my desktop. When I load a drawing up with xrefs attached, the xref file do not come up. I get the error message that there are unreconciled layers. I would try to repath the xref to locate the xref I now have on my desktop, and it will not locate the location, it simply goes back to the original path from the office directory.
    So today, I used Etransmit and was able to get 1 single sheet transmitted into a zip folder as suggested. Brought the etransmit zip folder home, extracted and saved onto a folder on my desktop, loaded the drawing, and STILL no xref files. Still gives me the error, unreconciled layers, and will not let me repath to find the xref on my desktop.
    WHAT THE HELL AM I DOING WRONG?!?!
  1. simple simple... connecting to 2006 via interop
    By btraemoore in forum .NET, ObjectARX & VBA
    Last Post: 29th Apr 2013, 03:39 pm
  2. Replies: 1
    Last Post: 23rd Nov 2010, 02:27 pm
  3. simple question
    By alijahed in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jun 2010, 11:30 pm
  4. simple dwg to pdf question
    By kippax in forum AutoCAD General
    Last Post: 3rd Nov 2009, 05:22 pm
  5. Simple Dim Question
    By Methuselah in forum AutoCAD Drawing Management & Output
    Last Post: 20th Apr 2006, 08:57 pm
