HELP:Advise on script to insert block to multiple drawings with more than 1 layout
vernonlee
I needed to insert a block into many drawings at the same location.
After some study, I am able to run this script with scriptpro.
ATTREQ 1
ATTDIA 0
-INSERT
"*d:\new block.dwg"
2527.1006043527,827.3694412067923
1
0
save
y
But the issue is i have 2 layout. The above script will only insert to the default layout only.
Can someone advise how insert in both layout?
Thanks
  • Replies 20
  • vernonlee
    11
  • BIGAL
    5
  • JamCAD
    3
  • steven-g
    2
Very simple the ctab variable can be used to change layouts so in your script (Setvar "ctab" "layout 2") and add Mspace Z E just in case your inside a layout viewport other wise it will insert in the model. NOTE must use brackets this is a mini lisp command in a script .
Ok. I will give it a shot.
BTW, since you mention it is now a mini lisp command in a script, i can still run it with scriptpro?
Thanks
You could use BIGAL's idea just adding the 2 lines to your script
CTAB
layout 2
I honestly don't know if it will make a difference, being an LT user I don't know the effects of adding lisp code to scripts
Try replacing your insert part of the script with this.
(foreach layout (layoutlist)
 (setvar "ctab" layout)
 (command "pspace")
 (command "-insert" "d:\new block.dwg" "2527.1006,827.3694" "1" "0"))
Sorry it will not work with LT Steven is correct just do it as a command you can do on one line if you like
Ctab "layout 2" use " if you have spaces in layout name.
Hi guys. Thanks for the input. I am using autocad full version.
I will try to study all inputs & see how to work it out.
Thanks
Hi JamCAD.
I add in as suggested in 2 different ways and i got errors for both.
1st way script
ATTREQ 1
ATTDIA 0
-INSERT
 (command "pspace")
1
0
save
y
1st way error
Command:
Command: _.SCRIPT
Enter script file name : D:\Office\AutoCAD\Scripts\03_Insert Block___Testing\insert block script 2.SCR
Command: ATTREQ
Enter new value for ATTREQ : 1
Command: ATTDIA
Enter new value for ATTDIA : 0
Command: -INSERT
Enter block name or [?]: (foreach layout (layoutlist)
(_> (setvar "ctab" layout)
(_> (command "pspace")
(_> (command "-insert" "d:\new block.dwg" "2527.1006,827.3694" "1" "0"))
Regenerating layout.
Regenerating model.
pspace
"pspace.dwg": Can't find file in search path:
C:\Windows\system32\ (current directory)
C:\Users\Vernon_Lee\appdata\roaming\autodesk\autocad 2014\r19.1\enu\support\
C:\program files\autodesk\autocad 2014\support\
C:\program files\autodesk\autocad 2014\support\en-us\
C:\program files\autodesk\autocad 2014\fonts\
C:\program files\autodesk\autocad 2014\help\
C:\program files\autodesk\autocad 2014\express\
C:\program files\autodesk\autocad 2014\support\color\
C:\program files\autodesk\applicationplugins\fusionplugin.bundle\contents\resources\
C:\program files\autodesk\applicationplugins\fusionplugin2013.bundle\contents\resources\
D:\office\autocad\lsp\
C:\programdata\autodesk\applicationplugins\autodesk importskp.bundle\contents\resources\
C:\Program Files\Autodesk\AutoCAD 2014\drv\
*Invalid*
; error: Function cancelled
Command:
2nd way script
ATTREQ 1
ATTDIA 0
 (command "pspace")
1
0
save
y
2nd way error
Command:
Command: _.SCRIPT
Enter script file name : D:\Office\AutoCAD\Scripts\03_Insert Block___Testing\insert block script 3.SCR
Command: ATTREQ
Command: ATTDIA
Command: (foreach layout (layoutlist)
pspace
Already in paper space.
Command: -insert Enter block name or [?]: d:
ew block.dwg
Invalid block name.
Command:
What did I do wrong? :oops:
 (command "pspace")
Got it working with this script. :shock:
ATTREQ 1
ATTDIA 0
ctab
A2
-INSERT
"*d:\new block.dwg"
1
0
ctab
A3
-INSERT
"*d:\new block.dwg"
1
0
save
y
Thanks guys :beer:
CTAB
layout 2
Two ways make lisp 1 line only unfortunately if it hits end of line before close bracket get error,
(foreach layout (layoutlist)(setvar "ctab" layout)(command "pspace")(command "-insert" "d:\new block.dwg" "2527.1006,827.3694" "1" "0"))
second save the foreach as a lisp then script just has two lines this is a universal way of doing it can be used elsehwere
(load "foreachtab")
(foreachtab "d:\new block.dwg" "2527.1006,827.3694")
(foreachtab (blknanme pt / )
 (command "pspace")
 (command "-insert" blkname pt "1" "0")
OMG i realised something. All layout tabs are names differently across my lots of drawings.:cry:
If this is the case, what is the solution? :(
Try this
ATTREQ 1
ATTDIA 0
(setq osnapsave (getvar "osnap"))
(setvar "osnap" 0)
 (if (/= 1 (getvar "cvport")) (command "pspace"))
 (command "-insert" "d:\\new block.dwg" "2527.1006,827.3694" "1" "0")
(setvar "osnap" osnapsave)
save
y
Hi JamCAD
Tested the script as indicated but got this error:-
Command:
Command: _.SCRIPT
Enter script file name : D:\Office\AutoCAD\Scripts\03_Insert Block___Testing\insert block script 5.SCR
Command: ATTREQ
Command: ATTDIA
Command: (setq osnapsave (getvar "osnap"))
nil
Command: (setvar "osnap" 0)
; error: AutoCAD variable setting rejected: "osnap" 0
(_> (if (/= 1 (getvar "cvport")) (command "pspace"))
(_> (command "-insert" "d:\\new block.dwg" "2527.1006,827.3694" "1" "0")
(_> )
Regenerating model.
-insert Enter block name or [?]: d:\new block.dwg Substituting [simplex.shx] for [helv.shx].
Substituting [simplex.shx] for [universExtraBlack].
Units: Millimeters Conversion: 1.0000
Specify insertion point or [basepoint/Scale/X/Y/Z/Rotate]: 2527.1006,827.3694
Enter X scale factor, specify opposite corner, or [Corner/XYZ] : 1 Enter Y scale factor : 0
Value must be nonzero.
Enter Y scale factor : *Cancel*
Command:
So i took out this 3 lines
(setq osnapsave (getvar "osnap")) (setvar "osnap" 0)
And also added "1" for the Y scale
This script now is this:-
ATTREQ 1
ATTDIA 0
 (command "-insert" "d:\\new block.dwg" "2527.1006,827.3694" "1" "1" "0")
save
y
And manage to get it to work. All layouts regardless of name has the new block inserted.
Thanks bro.
But then kindly advise the purpose of the 3 lines of code & if it is necessary to prevent future errors & how to incoporate it to the script such that it can work correctly.
Thanks again. :)
Try this
ATTREQ 1
ATTDIA 0
(setvar "osnap" 0)
save
y
Hi JamCAD
ATTREQ 1
ATTDIA 0
save
y
Thanks bro.
Thanks again. :)
Sorry, I'm trying to answer these questions on my phone and I'm not able to test it before I post. Those few lines of code are to disable the object snap so when you are inserting the block it doesn't accidentally snap to the incorrect point. I forgot that the system variable for the osnap settings is actually osmode. This should work now.
ATTREQ 1
ATTDIA 0
(setq osnapsave (getvar "osmode"))
(setvar "osmode" 0)
(setvar "osmode" osnapsave)
save
y
Hi BIGAL,
do not quite understand the process.
I will just stick to the basic script instead :P
Thanks for the help as well :beer:
(load "foreachtab")
 (command "pspace")
NP bro. Appreciate the help.
The revised script now works without issues. :D
Thanks :beer:
ATTREQ 1
ATTDIA 0
(setvar "osmode" 0)
save
y
I also added this 3 lines to my initial script base on layout names:-
(setvar "osmode" 0)
Script
ATTREQ 1
ATTDIA 0
(setvar "osmode" 0)
ctab
A2
-INSERT
"*d:\new block.dwg"
1
0
ctab
A3
-INSERT
"*d:\new block.dwg"
1
0
save
y
Edited by vernonlee
Thought this was discussed already OSMODE
OMG. You are right.
Now how did i copied the old code instead? :o :?
WIll test it when back in office but i believe should be no issue now. :oops:
