Results 1 to 8 of 8
    Junior Member rosswhiteeca's Avatar
    rosswhiteeca's Computer Details
    Windows
    hp 6735s
    4G
    Architectural
    AutoCAD 2013
    Dec 2011
    Penicuik, Scotland
    15
    Angry Stealth layers in model space...
    Hi,
    I have a complex drawing (155 layers) of a site, and although I can see all layers in paper space layouts, in model space I can only see the ones I exported as pdf's. I've turned all layers on (hence why I can see them in paper space) but they are still invisible in model space.
    I need to alter the drawing so this is proving very annoying!!
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Could a different CTB (plotstyle table) be applied to modelspace that's altering the display in modelspace only? From modelspace, enter the PAGESETUP dialog then Modify then uncheck Display with Plotstyle in the upper right corner
    Windows
    hp 6735s
    4G
    Architectural
    AutoCAD 2013
    Dec 2011
    Penicuik, Scotland
    15
    Hi nestly, thanks for your reply. I've had a look at that and it was already unchecked! Still no idea what's going on :-(
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,158
    Could you post a copy of the drawing, maybe with the majority of things deleted, just leaving a couple of sample objects that do and do not display, so someone could take a look, it would only need one layout viewport, so long as it still has the same problems you are experiencing.
  5. #5
    Windows
    hp 6735s
    4G
    Architectural
    AutoCAD 2013
    Dec 2011
    Penicuik, Scotland
    15
    Hi, I've managed to find a back up copy on my external hard drive which seems to be working I may still post the drawing as I'd like a solution in case it happens again! Thanks
  6. #6
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,158
    Just a thought, is it not something silly like all the objects have moved to paperspace ?
  7. #7
    AutoCAD 2013
    Nov 2011
    6,049
    Quote Originally Posted by steven-g View Post
    I like that question!
  8. #8
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    Check what colours the layers are in modelspace. E.g. if the layers are colour blue and you have a blue AutoCad background (whereas whoever created the drawing had a yellow AutoCad background) then you're going to struggle to see them. The layer colours may have been overridden to be something different in the paperspace viewports.
  1. Fill color model space versus paper space.. newb question
    By dan_m in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Nov 2014, 09:06 am
  2. Exporting Model Space or Securing Layers
    By jaredmccullough in forum AutoCAD General
    Last Post: 24th Apr 2013, 09:57 pm
  3. Acad 2010 - Text size changes in model space behave as if in paper space.
    By Trickinitup in forum AutoCAD Drawing Management & Output
    Last Post: 7th Sep 2011, 03:44 am
  4. AcadPViewport2 - Deleting items in model space that aren't seen inside paper space
    By lovemy65stang in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2009, 05:26 am
  5. Convert 3D AutoCAD Model Space Drg to 2D Model Space Drg
    By garycrampton in forum AutoCAD Beginners' Area
    Last Post: 22nd Dec 2005, 10:17 am
Tags for this Thread
