Select specific blocks inside polyline and update the selected Mtext/Text information
rk25134
Select the specific blocks inside polyline/polygon and update the selected Mtext/Text information into below mentioned tag values of the blocks
tag names: ST_NAME
HSE_NO
It should ask the Block name.
Are you talking about Attributed Block ?
What is the new text string that you want to replace the current one with ?
Sample drawing mostly describes the goal much more better than words ;)
I am trying to remember the post but I did a lisp for selecting text within a polyline it should be simple to modify to find a block and update the attribs is part2.
here is a start needs modifying to look for Insert, the dwg posted has no info about what is to be replaced need more detail.
; this is not finished code
(vl-load-com)
(defun getcoords (ent)
 (vlax-safearray->list
   (vlax-variant-value
     (vlax-get-property
   (vlax-ename->vla-object ent)
   "Coordinates"
(defun co-ords2xy ()
; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z
(setq numb (/ (length co-ords) 2))
(setq I 0)
(repeat numb
(setq xy (list (nth I co-ords)(nth (+ I 1) co-ords) ))
(setq coordsxy (cons xy coordsxy))
(setq I (+ I 2))
) ; end repeat
) ; end defun
; program starts here
; choose output file change acdatemp to what you want
(setq plobjs (ssget (list (cons 0 "lwpolyline"))))
(setq numb1 (sslength plobjs))
(setq x numb1)
(repeat numb1
(setq obj (ssname plobjs (setq x (- x 1))))
(setq co-ords (getcoords obj))
(co-ords2xy)
; write pline co-ords here
(setq numb3 (length co-ords))
(setq z numb3)
(setq ansco-ords "")
(repeat numb3
(setq ansco-ords (strcat ansco-ords (rtos (nth (setq z (- z 1)) co-ords) 2 3 ) " " ))
(setq ans (strcat "Pline " ansco-ords))
(write-line ans fout)
(setq ss (ssget "WP" coordsxy (list (cons 0 "Insert")))) ; selection set of Blocks within polygon
(if (= ss nil)
(princ "\nnothing inside")
(setq coordsxy nil) ; reset for next time
(setq numb2 (sslength ss))
(setq y numb2)
(repeat numb2
; this where you would do attrib bit
(princ "\n")
) ; end repeat2
(setq ss nil) ; reset for next poly
) ; end repeat1
(close fout)
Just use a lisp, ssget with a filter for the block UTUID and update, just pick street name 1st then select relevant blocks say by a polygon window. Plenty of examples around. I would do multiple at a time rather than 1 lot at a time.
Use fields value rk25134. you only have to do it once. Whatever is the value on the the TAGS ST_NAME and HSE_NO the TEXT string value will follow or is it the other way around? But still, FIELDS is the way to go.
Pbe nice idea just pick text as a field if you rename blocks update.
I guess we will never know if its enough to solve the OP's problem, perhaps the OP has all but given up on this thread. :)
Need a lisp for below requirement
I need to update automatically the block attribute of tag value (HSE_NO) from the text/mtext located in the same closed polygon.
Ex.
1. In a closed polygon/polyline there will be a text or mtext having some values that need to entered into the blocks which are locating in the same closed polygon/polyline
2. text/mtext is in layer HSENO and the block attribute is HSE_NO
3. I tool will find more than one text/mtext that need to entered into another block which is located in the same block.
