Massprop
Hello everyone,
I have searched an answer for my problem but everything I've seen explains what I have done.
I need to get the Moment of Inertia of a corrugated metal section, so I created it with Pline then converted it into a region. After I run Massprop on the section this is what I get:
---------------- REGIONS ----------------
Area: 6.7800
Perimeter: 54.7402
Bounding box: X: -12.0009 -- 11.9991
Y: 0.9798 -- 5.3638
Z: 0.0000 -- 0.0000
Centroid: X: 0.0000
Y: 3.4942
Z: 0.0000
Am I doing something wrong?
I have done it by hand already but this is bothering me since it has worked before.
Thank you all before hand :)
Thank you for your help.
What was the issue? I've exploded the file you sent, created a region and got the answer.
Thanks again :D
As far as I can tell, the reason it wasn't working is because it's not at zero elevation relative to the current UCS. (ie the elevation is reported as Z = -0.00001070 when the precision is increased in the UNITS dialog box)
Original Massprop analysis:
Area: 6.78002999
Perimeter: 54.74023995
Bounding box: X: -12.00085347 -- 11.99914653
Y: 0.97977829 -- 5.36377829
Z: -0.00001070 -- -0.00001070
Centroid: X: 0.00000939
Y: 3.49415511
Z: -0.00001070[/i]
Massprop analysis after moving to to Z=0.00000000
Area: 6.78002999
Y: 3.49415511
Moments of inertia: X: 102.54027605
Y: 308.11512515
Product of inertia: XY: 0.07828562
Radii of gyration: X: 3.88894171
Y: 6.74125416
Principal moments and X-Y directions about centroid:
I: 19.76205517 along [0.99999996 -0.00027226]
J: 308.11514652 along [0.00027226 0.99999996]
BTW The same result can be achieved by moving the UCS to the object, instead of moving the object to the UCS
