Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Senior Member CafeJr's Avatar
    AutoCAD 2010
    Oct 2013
    Brazil, São Paulo, Sorocaba
    219
    Default Exporting selected text to Excel Cell
    Guys,
    I need one help, someone knows one Lisp that I can get Texts (words) on AutoCad and export it in order of selection to a cell on Excel...
    Eg.: If I have 10 words, as I'll selecting it and when finished these then words will be exported to a cell (could be cels) to Excel.
    Thanks in advance...
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,249
    Can you explain your goal with an example ?
    Are you wanting to select one by one to keep them in the same order exported to Excel ?
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,716
    Getexecl.lsp it is a library of excel-autocad functions both ways.
    AutoCAD 2010
    Oct 2013
    219
    Quote Originally Posted by Tharwat View Post
    In these picture In trying to clarify the task.
    Tharwat, the selection is one by one, because I have a Big drawing with a lot of information, and I need to follow the names and select it to export by selection order. To show the example I put A and B, but it's only to exemplify, not is necessary to work with two collumns or two line of cells, only get the words and export it to Excel in order of selection, it will help a lot.
  5. #5
    AutoCAD 2010
    Oct 2013
    219
    Quote Originally Posted by BIGAL View Post
    Thanks Bigal, I will try it too.
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,716
    Your request is two parts, actually writing to excel is the easy bit and thinking about provide you always use A C C etc it can be done.
    Thinking about it now if you just make a list of text (A-1 B-1 B-3 A-2 ETC ) You can take 1st character and check if its A B C D etc and set column (asc(text)) last number A-23 = 23+row offset = cell row so if some missing will jump over blanks. B-23 = cell 2,27
    Thanks to Lee-mac for this it will give a number as an answer.
    Code:
    ; use say nth of your list of text selected (setq nthtext (nth x testlist))
    ; to use (setq cellnum (Lm:parsenumbers nthtext))
    ;;-------------------=={ Parse Numbers }==--------------------;;
    ;;  Parses a list of numerical values from a supplied string. ;;
    ;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
    ;;  Arguments:                                                ;;
    ;;  s - String to process                                     ;;
    ;;  Returns:  List of numerical values found in string.       ;;
    (defun LM:ParseNumbers ( s )
        (lambda ( l )
          (read
            (strcat "("
              (vl-list->string
                (mapcar
                  (function
                    (lambda ( a b c )
                      (if
                        (or
                          (< 47 b 58)
                          (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
                          (and (= 46 b) (< 47 a 58) (< 47 c 58))
                        b 32
                  (cons nil l) l (append (cdr l) (list nil))
        (vl-string->list s)
  7. #7
    AutoCAD 2010
    Oct 2013
    219
    Sorry Bigal, the text at AutoCad, isn't a specific address to Excel, it's any kind of text, to be exported to Excel in "any" cell. I didn't pay attention on AutoCad text that I wrote... similar a Excel cell address...
  8. #8
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    3,016
    Cool lisp rouitne
  9. #9
    AutoCAD 2010
    Oct 2013
    219
    Bigal, I don't know why, but I loaded the Getexcl lisp but it doesn't work, the command isn't recognized. I did it in two AutoCad softwares, 2012 and 2013 versions...
  10. #10
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,249
    Quote Originally Posted by CafeJr View Post
    The GetExcel.lsp is a function to deal to Excel files that release after the year 2003 and which their extension files would be formatted to .xls and xlsx ... etc so this function alone does not help you with any .
    Anyway , I have a plan to write a program with a dialog box to obtain the selected text strings before exporting them to txt format or Excel file with a format .csv . Would this be suitable for your needs ?
    I am busy at the moment but would write it since that I think it would be handy program in general .
    Tharwat
  1. Is it possible to remove a text string out of all selected text?
    By yonderbob in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Sep 2012, 03:12 pm
  2. Rotate all selected text
    By seventy9mph in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Mar 2011, 05:03 pm
  3. Exporting text
    By JimBob in forum AutoCAD Beginners' Area
    Last Post: 10th Feb 2009, 04:56 pm
  4. Replies: 5
    Last Post: 11th Oct 2006, 05:34 am
  5. Selected text fill
    By givrdad in forum AutoCAD General
    Last Post: 8th Feb 2006, 11:23 pm
Tags for this Thread
