Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Senior Member CafeJr's Avatar
    AutoCAD 2010
    Oct 2013
    Brazil, São Paulo, Sorocaba
    216
    Thank you Tharwat... I don't know if it's simple, but the idea is, is only collect a spread texts (words) in a drawing in order of selection... to export it to Excel.
  2. #12
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,124
    Quote Originally Posted by CafeJr View Post
    Try this program and let me know .
    Note: At the end of selecting texts , just press enter and type ( n ) or ( no ) to display the dialog for the last process .
    Code:
    (defun c:Test  (/ *error* _dialog dlg s name s l k save path o)
    ;;;        Tharwat 13.01.2015        ;;
      (defun *error*  (msg)
        (if (and dlg (findfile dlg))
          (vl-file-delete dlg)
        (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*"))
          (princ (strcat "\n** Error: " msg " **"))
      (defun _dialog  (/ id f)
        (cond
          ((not
             (and
               (setq dlg (vl-filename-mktemp nil nil ".dcl"))
               (setq f (open dlg "w"))
               (write-line
                 "test : dialog {label = \"Test Strings\"; width = 40;
                 : text { key = \"path\"; }
                 spacer_1 ;
                 : list_box { key = \"lst\"; height = 18;}
                 : boxed_row {
                 : button { label = \"Okay\"; key = \"oki\"; width = 12;}
                 : button { label = \"Exit\"; key = \"esc\"; is_default = true; is_cancel = true; width = 12;}
                 : button { label = \"Save to\"; key = \"sv\"; width = 12;}
                 f
               (not (close f))
           (alert "Can't load the temporary file <!>")
          ((or (not dlg)
               (not (> (setq id (load_dialog dlg)) 0))
               (not (new_dialog
                      "test"
                      id
           (princ "\n Can not load Dialog !")
          (t
           (start_list "lst")
           (mapcar 'add_list (reverse l))
           (end_list)
           (mode_tile "oki" 1)
           (set_tile "lst" "0")
           (action_tile
             "sv"
             "(if (setq path (getfiled \"Save to\" (getvar 'DWGPREFIX) \"csv\" 1))
                  (set_tile \"path\" path)
                  (mode_tile \"oki\" 0))
                (mode_tile \"oki\" 1))"
           (action_tile
             "oki"
             "(setq save t)(done_dialog)"
           (action_tile "esc" "(setq save nil)(done_dialog)")
           (start_dialog)
           (unload_dialog id)
        save
      (while
        (cond
          ((and (setq s (car (entsel "\n Pick Texts :")))
                (wcmatch (cdr (assoc 0 (entget s))) "TEXT,MTEXT")
           (setq l (cons (cdr (assoc 1 (entget s))) l))
          ((or s (not s))
           (princ "\nInvalid Selection !! Select text ONLY ")
           (initget 6 "Yes No")
           (or (not (setq k
                           (getkword "\n Missed !! Continue [Yes/No] <Yes> :")))
               (eq k "Yes")
      (if (and l (setq save (_dialog)) (setq o (open path "w")))
          (mapcar '(lambda (x) (write-line x o)) (reverse l))
          (close o)
          (princ "\n Well done ...")
        (princ "\n Exit by User ")
    AutoCAD 2010
    Oct 2013
    216
    Woowwwww... He he he... Thanks Tharwat!... It Works as good as I need!!!...
    The unique "delay" that I have it's work with spreadsheets (by the number of usages), I'm thinking if has a way to fill up one spreadsheet only (I don't know), or using a Ram memory to copy these texts to paste one a cell in a Excel file open... It's that possible?...
  4. #14
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,124
    I am happy that you liked the program
    I don't think that I got your point
  5. #15
    AutoCAD 2010
    Oct 2013
    216
    Sorry,
    Let me try to explain!...
    Every time that I use it, I'll create a spreadsheet (it's ok, no problem, it's help a lot even why I need to rewrite the path on Excel!).
    It'll be used to follow electrical cables on a drawing, think in one electrical installation I have one point (origin) and a target of the cable (instruments on the field), so, I have to do these follow the path texts (address of electrical pipes or cable trays) to select where the cable pass through, are many cable to do it one by one, you got it?...
  1. Is it possible to remove a text string out of all selected text?
    By yonderbob in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Sep 2012, 03:12 pm
  2. Rotate all selected text
    By seventy9mph in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Mar 2011, 05:03 pm
  3. Exporting text
    By JimBob in forum AutoCAD Beginners' Area
    Last Post: 10th Feb 2009, 04:56 pm
  4. Replies: 5
    Last Post: 11th Oct 2006, 05:34 am
  5. Selected text fill
    By givrdad in forum AutoCAD General
    Last Post: 8th Feb 2006, 11:23 pm
Tags for this Thread
