Madruga_SP Posted January 10, 2015 Share Posted January 10, 2015 Hi guys, I'm having trouble to create to 2 sufarces in autocad civil. I've exported 2 polifaces mesh from Topograph software. And I have to create 2 surfaces in autocad civil and represent fill area and cut area in the project. - layer: MalhaTriPROJ , color 21 - Surface Project -layer: MalhaTriTG, color: 132 - Surface Primitive I'm beginner with autocad civil and I tried to create that areas. But the problem the autocad is recognizing all over my project as fill and It isn't right. If anybody interested in my task I'll will really happy Sorry for my poor english. I'm brazilian, couldn't explain better as I wanted to. I hope you understand guys regards LLGSF-MALHAS-3D.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 10, 2015 Share Posted January 10, 2015 Ok cut 210 fill 967 A few problems 1st you need a proper civ3d template that has styles in it and copy both models in to it, if you dont have one use the default metric or imperial template this way you can at least view contours and check surface. 2nd explode both models once only this makes them individual 3dFaces Isolate the layer 1st surface, Using surface create add surface 1 under definition autocad objects add 3dfaces, tick save edges. Isolate the layer 2nd surface, Using surface create add surface 2 under definition autocad objects add 3dfaces, tick save edges. Under Surfaces, Utilities, Dashboard Volume, enter a volume name further down pick surface1 then surface2 Pick top left icon Volume will appear, it took me about 5 mins to do as I had to load styles into your dwg. Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted January 11, 2015 Author Share Posted January 11, 2015 (edited) HI BIGAL, Thank you for replay. I don't know what's wrong with my project. Could you please take a look in my file? I did exactly you said Regards http://www.4shared.com/photo/i-cgoeL0ce/test_hatch.html? Edited January 11, 2015 by Madruga_SP Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted January 11, 2015 Author Share Posted January 11, 2015 Hi, I think I got it! But I don't know how to export the Green and Red Hatches from autocad civil to autocad 2012. Could you help me please? Quote Link to comment Share on other sites More sharing options...
