KennyJ Posted January 12, 2015 Share Posted January 12, 2015 I'm having trouble getting the Title text to justify to the left on a custom table in Inventor. oGenericTable.TitleTextStyle.HorizontalJustification = kAlignTextLeft The above does not seem to do anything. The table title stays centered. even when I look at the text style I have set for the title it is set to left justify and the title is centered. I wonder if it is hard coded to stay centered? But if that was the case then why is (TitleTextStyle.HorizontalJustification) even part of that object? Quote Link to comment Share on other sites More sharing options...
KennyJ Posted January 20, 2015 Author Share Posted January 20, 2015 I got the reply below from the Autodesk staff on their community forums. It is not possible. "Hi, Sorry there is not such API. in UI we can’t justify it neither, it should be controlled by table style(Table(ANSI))-> text style(Note Text (ANSI)). But if you modify the justifications they don’t apply to the custom table title. Sorry if this is a bad news to you. Xiaodong Liang Developer Technical Services Autodesk Developer Network " Quote Link to comment Share on other sites More sharing options...
