vertical horizons Posted January 12, 2015 Share Posted January 12, 2015 Today, I opened Inventor 2013 & found that my ribbon (& associated tabs) are missing. I can not figure out how to turn then back on. I looked at the tutorial, but could not find the solution. You can see in the red ellipse that the ribbon is not there. (Sorry for the crappy picture. It was taken with my phone.) Any suggestions, as to where I should look? Quote Link to comment Share on other sites More sharing options...
ecshclark Posted January 13, 2015 Share Posted January 13, 2015 Looks like you undocked the ribbon bar. If so, the ribbon bar will be a window floating around somewhere on your screen. it may be hidden under another window. When you find it, RMB while hovering over the ribbon window, and select "Docking Positions", Top, Left, or Right. Quote Link to comment Share on other sites More sharing options...
vertical horizons Posted January 13, 2015 Author Share Posted January 13, 2015 I couldn't find the ribbon bar anywhere. This morning, I opened Inventor, and the ribbon bar was where it is supposed to be. Maybe my machine had a glitch. Quote Link to comment Share on other sites More sharing options...
gbradley Posted January 13, 2015 Share Posted January 13, 2015 Have you tried to Exit AutoDesk Inventor, and then restart the application? Oh I see that you did. Great, yeah it probably got moved. Quote Link to comment Share on other sites More sharing options...
