jsdrftng Posted January 13, 2015 Share Posted January 13, 2015 ok, i'm sorry if this has been asked before but i couldn't find it. I recently moved from autocad 2008 to 2012. my machine intel Xeon E5-1603 @ 2.8GHz 32GB mem win 7 64bit dual V4900 AMD vid cards autocad 2012 so my issue is this (and i have only found one other person asking about this) when i do a find/replace command it happens lickity split, but when i click "done" to exit it takes forever to close (about 6-10 seconds). In acad08 on my 32 machine it was instant. So what i have realized is that it's doing a regen at the exit. So i guess my question is, can i turn off the autoregen after i close the find/replace dialog box? my REGENMODE is currently . If that can't be done, is there another way to find/replace so that it doesn't do a regen after words? Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 13, 2015 Share Posted January 13, 2015 When you made the move from 2008 to 2012 did you also install the latest service pack? Quote Link to comment Share on other sites More sharing options...
jsdrftng Posted January 13, 2015 Author Share Posted January 13, 2015 yes, both of them. so a crappy workaround i'm doing at the moment (because this is really driving my OCD off the charts) is i am copying the blocks i want to change into a new drawing, do all my find replace, then copy back (with basepoint) also, i have installed the acadinfocenteroff Quote Link to comment Share on other sites More sharing options...
jsdrftng Posted January 15, 2015 Author Share Posted January 15, 2015 ok, so on the autodesk forum i was told "There is no way to turn off the forced REGEN after FIND is complete." There has to be something else that can be done. Surely i'm not the only one having this frustration. Do newer versions of Autocad do the same thing with no variable to control it? i'd rather use autocad 2008 if this is the only thing i can do Quote Link to comment Share on other sites More sharing options...
socrates Posted January 16, 2015 Share Posted January 16, 2015 Try REGENAUTO and turn it off, Let me know how it worked Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 16, 2015 Share Posted January 16, 2015 Do all regens take that long? It sounds kinda like AutoCAD is looking for something and not finding it where it should be. Maybe it's looking for a font or a shape file that is not on your machine or not in the right place. Did you have any object enablers before the upgrade? When you open the drawing, do you get any warnings about missing fonts or .shp files? Also, check your text styles and make sure that there aren't any missing fonts assigned to any of them. Quote Link to comment Share on other sites More sharing options...
jsdrftng Posted January 16, 2015 Author Share Posted January 16, 2015 Try REGENAUTO and turn it off, Let me know how it worked regenauto is already off and regenmode is Do all regens take that long? no, a brand new drawing doesn't take that long to regen, the larger my file gets, the longer it takes to regen. typical size for my drawing is 10-20Mb i have a few thousand dynamic blocks all with attributes (attributes is what i am find/replacing) Did you have any object enablers before the upgrade? no When you open the drawing, do you get any warnings about missing fonts or .shp files? no Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 16, 2015 Share Posted January 16, 2015 When you say you are not getting any warnings at opening, have you checked the command line history by opening the text window? Are you sure that you are not missing any fonts by at least checking your styles to make sure they are being found? Is there any chance that a font has been substituted in any text items, including attributes and all other possibilities? Sorry for the focus on fonts, but it seems like a good thing to rule out first since the delay seems to be related to text editing. Quote Link to comment Share on other sites More sharing options...
jsdrftng Posted January 16, 2015 Author Share Posted January 16, 2015 (edited) When you say you are not getting any warnings at opening, have you checked the command line history by opening the text window? Are you sure that you are not missing any fonts by at least checking your styles to make sure they are being found? Is there any chance that a font has been substituted in any text items, including attributes and all other possibilities. Sorry for the focus on fonts, but it seems like a good thing to rule out first since the delay seems to be related to text editing. it's cool, i understand. No missing fonts Here is my start up Customization file loaded successfully. Customization Group: ACAD Customization file loaded successfully. Customization Group: CUSTOM Customization file loaded successfully. Customization Group: AUTOCADWS Customization file loaded successfully. Customization Group: AUTODESKSEEK Customization file loaded successfully. Customization Group: MODELDOC Customization file loaded successfully. Customization Group: CONTENTEXPLORER Customization file loaded successfully. Customization Group: ACFUSION Customization file loaded successfully. Customization Group: EXPRESS Regenerating model. AutoCAD menu utilities loaded. Command: COMMANDLINE Command: _RIBBON Command: Command: I guess it would help to see the start up on a file that takes longer to regen (duh) Heres what i see when opening one of my larger files Opening an AutoCAD 2010 format file. Resolve Xref "894-BeeSafe-Details": \\Rcd-main\1-rcd\RCD\2014\894-BeeSafe(SSI)\Jason\894-BeeSafe-Details.dwg "894-BeeSafe-Details" loaded: \\SetzerCO\1-rcd\RCD\2015\894-BeeSafe(SSI)\Jason\894-BeeSafe-Details.dwg Regenerating model. AutoCAD menu utilities loaded. Command: Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application. Command: Edited January 16, 2015 by jsdrftng i'm dumb Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 16, 2015 Share Posted January 16, 2015 Okay, start-up looks good. How about my two other questions? Once you rule out a font issue, try turning off the communications center. Quote Link to comment Share on other sites More sharing options...
jsdrftng Posted January 16, 2015 Author Share Posted January 16, 2015 "communications center" is that the same as info center? if so, thats off. as far as the fonts go, the only fonts i use are arch and haettenschweiler. my drawings are all started from my own template (meaning i don't import other peoples things, objects, fonts, etc...into my drawing). Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 16, 2015 Share Posted January 16, 2015 Yeah, that's it, info center. Change the hardware acceleration. I've had turning it on or off help with performance related issues. Quote Link to comment Share on other sites More sharing options...
jsdrftng Posted January 16, 2015 Author Share Posted January 16, 2015 no change with Hardware acceleration Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 16, 2015 Share Posted January 16, 2015 One more thing on the fonts, check your pathing make sure that those fonts reside in the folder specified for font mapping. While you are there, have a look around and make sure everything else is set-up properly. After that, I think we have completely ruled out the possibility of a font issue. Quote Link to comment Share on other sites More sharing options...
jsdrftng Posted January 16, 2015 Author Share Posted January 16, 2015 i don't know how to check "mapping". i mean, i dropped the arch font in with the other fonts in the fonts folder of acad. i dunno how else to check mapping. Its seems though, if it were a font that i would have a slow regen at the beginning of my file right? so for example, if it were a font issue, i could start a new file, do some text commands, then hit regen and see the issue right away? or no? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 16, 2015 Share Posted January 16, 2015 The first tab in options: Quote Link to comment Share on other sites More sharing options...
jsdrftng Posted January 16, 2015 Author Share Posted January 16, 2015 ahh, yea mine has the fonts i'm using in the folder it's mapped to Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 16, 2015 Share Posted January 16, 2015 Good. Any custom hatches or linetypes? Quote Link to comment Share on other sites More sharing options...
jsdrftng Posted January 16, 2015 Author Share Posted January 16, 2015 check this out. Here is a link to my dwg http://gofile.me/2BUU3/C8MyIU7R open this up, there are (4) plan views from left to right and (3) top to bottom. go to the box 2nd from the left and at the top. This is "Partition & Unit Layout" for 1st floor. select all the studs and do find replace, then hit esc. and tell me if it takes a few seconds or if it's instant. I think i might be on to something. My 2012 upgrade was recent, and so far all the file i am working on have been created with acad 2008. I wonder if i need to start a drawing from scratch in 2012? (which i do have one in the works but it's still pretty new) Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 16, 2015 Share Posted January 16, 2015 I don't think starting from scratch will be necessary. It wouldn't to try a quick experiment though. Block an entire drawing into a fresh template and explode it. Then see if the same thing is happening. Quote Link to comment Share on other sites More sharing options...
