Results 1 to 9 of 9
    Full Member
    AutoCAD 2013
    Jan 2015
    50
    Default Counting Blocks Within a Boundary
    Hello, all. I have a question concerning block counting. I have become familiar with the BCOUNT command, but I wanted to take it one step further for my particular application.
    What I have is several viewports within a drawing. Each viewport represents a particular floor of a building. Furthermore, within each floor are "loops" defined by colored, dashed lines in which there reside certain devices (blocks). Identical devices may exist within other loops on the same floor.
    Here's the question: Is there a way to count (and possibly export that data to a spreadsheet) the number of blocks that reside within each loop boundary? The boundaries are rarely simply rectangles. It's easy to count the number of blocks within a viewport, but I'm having trouble figuring out (if there even IS a way) how to count the number of blocks within my loop boundaries.
    **I should clarify and say that, when I say viewports, what I really mean is layouts. There is one viewport per layout/floor. Sorry if this caused any confusion or cringing.
    Thanks in advance.
    Beef
    Super Member lamensterms's Avatar
    lamensterms's Computer Details
    Windows 7 - 64bit
    Manufacture
    lamensterms's Discipline Details
    Steel Detailer
    Manufacture
    3D Modelling - Mechanical & Structural 2D Detailing - Shop Drawings
    AutoCAD 2014
    May 2011
    Berwick, VIC, Australia
    569
    Hi Beef,
    As far as selecting blocks within a loop/closed polyline - may I suggest the rountine in post #2 of this thread... http://www.cadtutor.net/forum/showth...in-a-polyline&
    Here is a great LISP routine (by Lee Mac) that counts blocks with the option to export to a CSV file (can also insert a table/schedule into your drawing. http://www.lee-mac.com/blockcounter.html
    Use these routines in conjunction and you should be all set.
    Full Member
    AutoCAD 2013
    Jan 2015
    50
    Thank you, Lamensterms. This looks perfect! I've never used scripting in AutoCAD before. Can you tell me, is this C programming language?
    *EDIT*
    Also, is there not a way to use the DATAEXTRACTION command (that already exists) in conjunction with this script?
    Beef
    Windows 7 - 64bit
    Manufacture
    Steel Detailer
    Manufacture
    AutoCAD 2014
    May 2011
    569
    These are both LISP programs. They can be loaded via the Tools menu > Load Applications...
    There is a whole forum here at CadTutor dedicated to LISP. Some very helpful folk with some very handy solutions to problems.
  5. #5
    Full Member
    AutoCAD 2013
    Jan 2015
    50
    Ah, so it's a programming language all on its own. Interesting. I'll have to look into this more closely. Thank you so much for your help.
    Beef
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,714
    Just change *text to Insert and try this
    Code:
    ; get text with closed pline example
    (defun getcoords (ent)
      (vlax-safearray->list
        (vlax-variant-value
          (vlax-get-property
        (vlax-ename->vla-object ent)
        "Coordinates"
    (defun co-ords2xy (/ xy)
    ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z
    (setq numb (/ (length co-ords) 2))
    (setq I 0)
    (repeat numb
    (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))
    (setq co-ordsxy (cons xy co-ordsxy))
    (setq I (+ I 2))
    ; program starts here
    (setq plist (ssget (list (cons 0 "lwpolyline"))))
    (setq numb (sslength plist))
    (setq J 0)
    (repeat numb
    (setq co-ords (getcoords (ssname plist J)))
    (co-ords2xy)
    (setq ss (ssget "WP" co-ordsxy (list (cons 0 "*text")))) ; selection set of text within polygon
    (princ (sslength ss)) ; this is howmany texts etc
    (setq co-ordsxy nil)
    (setq J (+ J 1))
    (setq ss nil)
    ) ; end repeat
  7. #7
    Full Member
    AutoCAD 2013
    Jan 2015
    50
    BIGAL,
    The code that lamensterms directed me to works pretty well, but I definitely appreciate your input. Maybe I'll try this one too and see what the difference is. It might help me to understand the language.
    Thanks!
    Beef
  8. #8
    Windows 7 - 64bit
    Manufacture
    Steel Detailer
    Manufacture
    AutoCAD 2014
    May 2011
    569
    Hi again Beef, it would be pretty easy to bring these two routines together into one command. That is something I would be happy to help you with. My knowledge of LISP is pretty limited, but it can be quite easy to build a good routine, combining a few different routines. Good luck and please let me know how you go.
  9. #9
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    I moved your thread to the AutoLISP, Visual LISP & DCL Forum.
  1. Counting Blocks
    By Michaels in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Aug 2010, 09:39 pm
  2. Counting Blocks
    By jagape in forum AutoCAD General
    Last Post: 9th Jun 2009, 11:37 pm
  3. Counting Blocks
    By jagape in forum AutoCAD Beginners' Area
    Last Post: 26th Feb 2008, 08:00 pm
  4. counting blocks using ATTEXT
    By explorer in forum AutoCAD Drawing Management & Output
    Last Post: 19th Jul 2007, 05:05 pm
  5. counting the blocks, how will i add new column...?
    By madaryl in forum AutoCAD General
    Last Post: 1st Mar 2006, 04:10 am
Tags for this Thread
