miroslav_s Posted January 14, 2015 Share Posted January 14, 2015 Hi, I am using Autocad Architecture to make this drawing and I want to use command roof to make my roof (of course). The house I drew has wall dimension 10 x 10 meters. When I draw the roof with the roof command I get a pyramid hip roof. I know that in order to change from “pyramid hip roof” to “open gable roof” I need to pull the blue handle on the top. Unfortunately there is only one blue handle to pull. This is because the house has equal sides but there must be a way to make an open gable roof, on this house right? Thanks in advance. Miro Quote Link to comment Share on other sites More sharing options...
danellis Posted January 15, 2015 Share Posted January 15, 2015 As you create your roof read the command line to get the GABLE prompt option - this will let you tell it which edges of the roof need to be gables and which don't. dJE Quote Link to comment Share on other sites More sharing options...
miroslav_s Posted January 16, 2015 Author Share Posted January 16, 2015 As you create your roof read the command line to get the GABLE prompt option - this will let you tell it which edges of the roof need to be gables and which don't. dJE Yes, I did as you said and it worked out just fine. Thank you Quote Link to comment Share on other sites More sharing options...
SLW210 Posted January 16, 2015 Share Posted January 16, 2015 I moved your thread to the Architecture & ADT Forum. Quote Link to comment Share on other sites More sharing options...
danellis Posted January 18, 2015 Share Posted January 18, 2015 Glad it worked for you, Miro, happy to have helped dJE Quote Link to comment Share on other sites More sharing options...
