tama010 Posted January 14, 2015 Share Posted January 14, 2015 Hello When I was trying to textoverride a selected dimension text created by a AMPOWERDIM I noticed something very weird. If I create multiple dimension with AMPOWERDIM without exiting the command, I noticed the override will work for the first dimension created, but the rest of the dimension will not override correctly. Anyone has a clue whats going on? Thank you (vl-load-com) (defun c:FOO (/ ss oDim s) (if (setq ss (ssget ":S:E" '((0 . "DIM*")))) (progn (setq oDim (vlax-ename->vla-object (ssname ss 0))) (prompt (strcat "\nTextOverride: " (if (and (vlax-property-available-p oDim 'textoverride) (/= "" (setq s (vla-get-textoverride oDim))) ) s "<Empty String> " ) ) ) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
