Page 8 of 8 FirstFirst ... 6 7 8
Results 71 to 79 of 79
  1. #71
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I'll have to look that up. I'm flying into Bozeman with my wife, staying the night then heading down to Gardiner. That will be our base of operations for five days. Coffee? Sure. But I'll warn you....I'm good for ten cups!
  2. #72
    Full Member ConfusedStudent's Avatar
    AutoCAD 2013
    Jan 2015
    Montana
    40
    Bozo is about 2 hours farther west of me. But if you're up for a road trip or if I get some time off you and your wife are welcome for a visit!! I always have coffee - it's a staple food here
  3. #73
    Senior Member
    Hondatek's Computer Details
    Win7
    dell T5400, dell optiplex 745
    AutoCAD 2013
    Oct 2014
    Houston, Tx
    113
    Confused go check my plate one please. Dosen't look right to me.
  4. #74
    Forum Newbie
    AutoCAD 2013
    Aug 2015
    4
    I Am Absolutely Lost With This Exam With Help Of Seeing Visuals Here I Was Able To Construct The I Beams,The Footings, And One Girder. I am lost as to what the spacing even is bewtween the top/bottom of the girder to the footing and a proper way of dispersing them around where they need to be Also as i move on to other plates am i starting a whole new drawing with the same setup?. Im all around completely lost with this program at this point, Penn Foster is truely disapointing with how they unleash there projects like this with minimal introduction. I took the program with more interest in gaining knowlede to use on smaller scales for a Welding And Machine Shop Cnc machining not constructing a building head to toe.
  5. #75
    Senior Member
    Win7
    AutoCAD 2013
    Oct 2014
    Houston, Tx
    113
    I go look at my posts. I got a 100 on this project.
  6. #76
    Forum Newbie
    AutoCAD 2013
    Aug 2015
    4
    Ok i will try to follow your posts, Thank you very much Honda
  7. #77
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    The distance between the top of slab and the bottom of the beam is supposed to be 10'-0". The slab thickness is 6". I believe the distance from the top of the footing to the top of the slab is 5'-0".
    I think you took the wrong course as nothing in the Penn-Foster program will prepare you for CNC machining.
  8. #78
    Forum Newbie
    AutoCAD 2013
    Aug 2015
    4
    Ok i will try to go from that Thank you so much! What do you mean by that? I live right next to a Welding And Machine Shop Where my father works. They use autocad to construct things to cut out with theyre cnc machine. I needed to learn how to use autocad as that is what they used. I am a welder who In highschool/college did Manual drafting/welding symbols/and blueprint reading. So is why i figured itd be my best bet to do that class. I dident know id have to do the manual drafting all over/ not touch autocad till months later. But how is it that the advanced nature of this program wouldent make it easyer for me to construct simple objects for a cnc machine?
  9. #79
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Quote Originally Posted by TwistedNuggz View Post
    AutoCad will help you. What Remark meant was that the structural steel course you are taking won't go near either CNC control or the typical day to day stuff that goes through a fabrication shop. Use the course to learn control of the program, and tie that knowledge in with what you already know and will learn about the fabrication business hands on.
    By the way, Autocad does not automatically make drawings in CNC language. It can't easily be directly plugged into the CNC machines, but there are a few intermediary programs that can connect the two together by using AutoCad's ability to export a dxf file that can be translated into CNC machine control instructions. (Repeat this mantra 5 times a day: Closed Polylines)
    A lot of fabrication shops even skip the intermediate software and manually input the dxf pattern dimensions directly into the CNC machine control console with their actual fingers.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  1. Penn Foster Structural Elective
    By coreyjaywilliams in forum Student Project Questions
    Last Post: 5th Oct 2015, 10:38 pm
  2. Penn Foster Civil Drafting With Autocad Project 6
    By taylorklepal in forum Student Project Questions
    Last Post: 21st Aug 2013, 11:25 am
  3. Penn Foster Structural drafting
    By redcav01 in forum Student Project Questions
    Last Post: 30th Dec 2012, 05:01 pm
  4. Penn Foster Drafting with Autocad
    By sethtb1 in forum Student Project Questions
    Last Post: 27th Dec 2012, 05:02 pm
  5. Structural drafting project Plate 2 (penn foster)
    By ANC2008 in forum Student Project Questions
    Last Post: 13th Jul 2011, 11:47 pm
